11-28-2020, 12:03 AM | #1 |
Drives: 2010 camaro l99 ss Join Date: Nov 2020
Greetings from Finland, good tips is needed
What kind of carb leagal upp grade package (cheap and good) Do you recommend for the 2010 l 99 camaro? I think about 600-650 whp is good for the original tranny.
The idea is to replace bigger injector and a more volume fuelpump and turbo or supercharger kit... Should I change the cam and put an afm delete kit with lifters? Or can I afm tuner off for the original cam? Cats I have must to keept and carb leagal kit must be on the Finnish car register. Now i have kn cai and jegs catpack, the power should be more.. Thank you very much and forgive me for my bad English |
11-28-2020, 08:25 PM | #2 |
Hello, from your description about what you want, I'd steer you towards either a Whipple or Magnuson supercharger kit (come with injectors, fuel pump or BAP (boost-a-pump)), or an AGP twin turbo setup.
To hit your target goal of 600-650whp, you'd definitely need to change the camshaft, lifters, springs, and pushrods. Depending on cam size, it might require the addition of a stall converter as well. On an LS3 car, a Whipple 2.9L, 4.00" pulley, LS9 camshaft, long tube headers, full 3" exhaust, and custom dyno tune made 600rwhp. https://whipplesuperchargers.com/ https://agpturbo.com/ |
11-28-2020, 10:03 PM | #3 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
15-20k$ just sayin..... be prepared.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
11-28-2020, 11:59 PM | #4 |
Thanks for the advice. Whipple is an interesting package and looks great!!
What do you recommend for stage 1 cam and lifters with supercharger? Thanks again. |
11-29-2020, 07:30 PM | #5 |
The LS9 cam is a good cam for the price, about $130 or so. Otherwise pretty much any STG 1 cam offered by BTR, TSP, etc., would work. I'm running a custom grind, I'll PM you the specs.
