03-18-2019, 02:39 PM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
2010-2015 Camaro LED Trunk Lighting Kit
2010-2015 Camaro LED Trunk Lighting Kit Starting At $37.95 With Code PHIL5 At Checkout
Adding LED lights to the trunk of your Camaro, not only make it easier to find things at night but adding a color option is a great way to add some style to your show car. This 2010-2015 Camaro Interior RGB LED Lighting Kit is the easy way to upgrade to LEDs. Our Camaro trunk lighting kit. Our kit is a plug and play replacement for the weak factory trunk light. It consists of a 24” led strip of either BRIGHT or SUPERBRIGHT SMD LEDs and is self-adhesive for easy installation. Simply remove the factory bulb and plug in the led strip and you are done! Installation takes about 15 minutes and instructions are provided. Colors available are red, blue, white, green, yellow. Orange and Aqua are available in superbright only. https://www.rpidesigns.com/shop/item...-lighting-kit/ |
11-18-2019, 02:30 PM | #2 |
