Old 09-15-2018, 04:41 PM   #1
nty1234
nty1234's Avatar
Drives: 2015 2SS Summit White
WTB: Cat delete pipes
Looking for a set of Catless Mid-pipes, thanks!
nty1234 is offline   Reply With Quote
Old 09-15-2018, 05:19 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I have a set and an x pipe in the for sale section... the cat pipes are 3" on the header end and 2 1/2 out. The x pipe is 2 1/2".
Not sure exactly what your looking for...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 09-15-2018, 09:08 PM   #3
nty1234
nty1234's Avatar
hmmm I should have been more clear. Just bolting it up to the stock headers for now so I think 3" is too big correct? just going catless for my lsa conversion really.
Old 09-16-2018, 01:40 AM   #4
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
I've got a set of BBK cat deletes with wideband bungs if you need to tune.
I'd take $100 + shipping.
Looked like this new:
Looks like this on each side with extra bung for wideband:
These: http://www.bbkperformance.com/produc...ce-pipes-.html
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 09-16-2018, 09:25 AM   #5
nty1234
nty1234's Avatar
Im interested, can you shoot me a price shipped to Novi, 48374? and what gaskets should I get, I'm assuming I shouldn't reuse these if you still have them. I remember when I installed high flow cats I went through 3 different sets of gaskets due to poor fitment properties.
