03-10-2013, 01:55 PM | #1 |
Drives: Pontiac G8 GT Join Date: Dec 2010
60lbs injectors fs
I have these 60lbs injectors forsell. Thought I needed these when I did my motor but dont. I paid 300 off ls1tech
250shipped These are ev1 connectors but they come with plug and play harness. So these will work with our cars Specifications: Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required) Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min Gain: 0.11ms/mg Offset: 0.055ms Turn on time @ 14VDC: 1.14ms Turn off time: 0.85ms @ 600KPa Connector: Bosch EV1 Series: DEKA 4 ( DEKA IV ) Orifice Type: Multi-orifice Spray Pattern: 30 Degree Spray Cone Factory fitted with Viton upper and lower o-rings 48mm end to end |
07-14-2014, 03:07 PM | #2 |
Drives: 2012 zl1 Join Date: Jul 2014
Do u still have them?
