07-18-2020, 04:14 PM | #1 |
Drives: 2018 zl1 10 speed Join Date: Oct 2018
How to prime your alky methanol system
Hi guys so i feel like a rookie here but id appreciate help .
Can anyone give me pointers on how to prime the system for the longest i didn't know you had to routinely prime it so you k ow things are operating properly.? |
07-18-2020, 08:51 PM | #2 |
Drives: Camaro Join Date: Jun 2018
You don’t prime the system per-say. The pump should always sit lower then the tank and therefore gravity feed. To test the system, the alky control kit has a test button and the led monitoring lights you mount separately will turn to green when the system has built pressure and is spraying as you hold the test button down. If you really want to check it, leave the intake tube with the nozzle installed off the car, power on the alky kit while the car is off and push the test button.
07-18-2020, 09:25 PM | #3 |
Roger that! Thanks alot brother ill test it out in the morning
07-18-2020, 10:43 PM | #4 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’ve spoken with Alky and it was suggested to regularly test the system to ensure pump spraying and meth built up to the line. I do it whenever the car has not been driven for more than a day.
Turn car on. Let idle and temps to come up. Bring rpm up to about 1200-1500 rpm and press and hold the test button. The light should come up red, meaning it’s spraying and then it’ll turn green meaning full spray. At this point rpm should drop a bit. Then it’s done and primed. |
07-18-2020, 10:45 PM | #5 |
It was also recommended to have pumps rebuilt every 2 years. I’ll be sending mine every year and buy an extra while one is out for rebuild.
07-19-2020, 11:39 AM | #6 |
Big help im glad i got help from you guys the system is 7 months and sometimes the car is not driven for weeks i just assumed keeping the tank full was all i needed until you guys helped with information. There aren't videos or tutorials on YouTube but i know now the importance of regularly checking to ensure its operating
07-20-2020, 08:08 AM | #7 |
The first time you run it you're supposed to disconnect the line and hit the test button. Spray it into a bottle and you can pour it all back into the tank. This is to purge the air out of the lines.
I'll do this after the car sits for the winter too. Otherwise like mentioned above just rev it up a bit and hit test until you get a green light. Then you're gtg. |
07-20-2020, 05:54 PM | #8 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
I ran the AEM for over 3 years, never had a failure with it not spraying, however I would test it every time you plan on going to the track. Very easy to do as Juiced said, remove the line, put the hose in a water bottle and hit the test button or course with the ignition on to activate the system.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
