#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction Discussions
Old 07-27-2020, 04:14 PM   #1
SONiC MOjO
Drives: 2018 Zl1 A10
Belt length help.
I have a Mag2650 and a 9.1 lower pulley.
Can someone please help with a belt length or
A chart of some sort.
I’ve contacted Magnuson and they’re unable to help.
SONiC MOjO is offline   Reply With Quote
Old 07-28-2020, 06:13 AM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
What is your upper pulley? What belt was sent with the kit?
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 07-28-2020, 08:26 AM   #3
SONiC MOjO
It’s just the stock upper, 90mm
Belt is for a stock lower pulley. . .
Old 07-28-2020, 01:42 PM   #4
toohighpsi
Drives: 2015 C7 Z06 M7
Longest that Magnuson will have is a 80865 (80 is 8 rib, 865 is 86.5" length) you'll need longer than that (as you know).
You'll have to make an estimate of length and hit up your local auto parts store. Quick back of envelope calcs show the stock lower has a circumference of 25.1", your 9.1" lower has a circumference of 28.6". Since the belt wraps around about 2/3 of the lower you my guess that you need a belt that is about 2.3" longer.
Check the belt that Magnuson sent you, and add 2.3" to the last 3 numbers - so if you have a 80865 you need an 80888 - plus or minus about .5 (the last number). There is also a good chance you won't be able to get an 8 rib from your store, so just go with a 7rib (70888) or even 6 rib (60888) to make sure you end up with the right size. Once you dial in exactly right length (tensioner at nearly full tight with new belt) then you can go online and order the correct length 8 rib belt.
I normally buy a few belts around the correct length when I visit the store, then return the once that were incorrect later to save trips back a fourth.
Mike
toohighpsi is offline   Reply With Quote
Old 07-28-2020, 01:57 PM   #5
SONiC MOjO
Mike
Perfect, Thank you
Old 07-28-2020, 06:27 PM   #6
laynlo15
laynlo15's Avatar
Thanks Mike I was just about to chime in and you got it taken care of.
Old 07-28-2020, 06:29 PM   #7
laynlo15
laynlo15's Avatar
I bought mine from Napa, they have their own line that is made by Gates and you want to use the FLeet Green belts.
