Old 03-26-2013, 05:55 PM   #1
dab86
dab86's Avatar
Drives: 2017 Camaro 1LE
JBA and X-Pipe Question
I have LT Headers and a full 3 inch JBA competition exhaust with off road mid pipes. Are these consider straight pipes or is there an X-pipe or H pipe in there too? If not, should i consider getting an X-pipe for my set up? Does the X-pipe replace the mid pipes or does it go before them? Not very knowledgeable about xpipes except they can help with low end torque.
dab86 is offline   Reply With Quote
Old 03-26-2013, 06:49 PM   #2
LS3SuperSport
HotRod
LS3SuperSport's Avatar
Drives: 2010 Camaro 2SS M6 Black/IO Int.
The JBA system has an H-pipe
LS3SuperSport is offline   Reply With Quote
Old 03-26-2013, 07:03 PM   #3
dab86
dab86's Avatar
Ok thank you! Is that worth switching out for an X pipe or not that big of a difference.
Old 03-26-2013, 07:20 PM   #4
LS3SuperSport
HotRod
I have the same set up as you and I'm not changing it.. I honestly couldn't tell you if there's much difference.
Old 03-26-2013, 07:48 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
X-pipe is supposed to help the top end, h usually sounds better.. Had a 3" MBRP LS3 X, too loud & too much drone for me, replaced with an L99 MBRP 3" resonated H and I'm much happier. No dyno comparison but the H and X logged 60-100 mph times with HPTuners are equal at 4.2 sec. on my setup. (same tune)
Iam Broke is offline   Reply With Quote
