04-12-2018, 06:36 PM | #1 |
Drives: 2010 SS Auto Join Date: Nov 2017
Battery Drain Question
Hey folks,
I bought a 2010 SS last fall, it was having trouble starting (weak battery). If I ran the car every day, it was not an issue. I trickle charged it over the winter, this spring, fired right up. I took it about 70 miles the other night, parked it, next morning, battery was completely dead. I tried charging it, no luck, couldn't even jump start it. I switched out the battery and it fired right up. However, here is my question. I disconnected the ground terminal and with the meter, I am still pulling about 1 amp of draw; is this normal? I pulled every fuse in the car and that didn't change anything. Any ideas or comments? Thanks! Spence |
04-12-2018, 07:51 PM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
It's just the justice department's gps logger no big deal
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-12-2018, 08:15 PM | #3 |
Whew, I knew it had to be something simple!
04-12-2018, 08:16 PM | #4 |
Drives: 2013 Black SS/RS Join Date: May 2017
Please get a new battery tomorrow. Problem solved.
04-12-2018, 08:26 PM | #5 |
I have a new battery in it. My issue is the 1 amp draw. I am trying to track down a short.
04-14-2018, 10:38 PM | #6 |
I ruled out alternator and battery cable down by the starter. Any ideas?
Thanks |
04-14-2018, 10:46 PM | #7 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I think there is a light in my trunk, if I open it that would be about 1amp. I'm assuming you open the trunk to check it. If you remove the bulb does it drop down?
Any aftermarket stuff like alarms etc? |
04-15-2018, 07:23 AM | #8 |
376 cubic inches of fun
Do you know there are three fuse boxes in the car?
04-15-2018, 08:44 AM | #9 |
Drives: o Join Date: Jun 2017
Theres modules that will show light draws all the time. 1 amp seems high. But maybe not accurate. Trunk light probably more than 1 amp.
I'm betting your alright. Your problem was the battery. Just to safe, make sure the alternator is keeping up. Driving around with a bad battery is hard on the alternator. |
04-15-2018, 05:29 PM | #10 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
It is too high. You should be drawing milliamps only. I generally shy away from electrical issues, having a pro take a look at it.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
04-15-2018, 07:24 PM | #11 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
Start pulling out fuses one at a time and replace until the draw stops. I had to do that on my boat. It was the radio.
04-15-2018, 09:49 PM | #12 |
Thanks for chiming in guys.
I pulled every fuse (in all three boxes) while my dad watched the meter. I did tape off the trunk switches. I ran it yesterday, I kept the new battery in it, it stayed at 14.7 volts this morning. However, I went out this afternoon and it was at 12.1 but quickly ran up to 14.7. |
04-16-2018, 05:06 AM | #13 | |
04-16-2018, 05:29 AM | #14 |
No draw. I used the dic to measure the volts.
