09-23-2021, 02:18 PM | #1 |
Drives: 2013 Camaro SS Join Date: Feb 2017
Locking connector
I'm having trouble with these connections with the white locking tabs. Is there a trick to getting them off. I feel stupid but I'm afraid of breaking the nipple off.
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 Last edited by StingrayblueSS; 09-23-2021 at 02:38 PM. |
09-23-2021, 02:55 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
IIRC you just squeeze the white and pull off the line.
09-23-2021, 03:01 PM | #3 |
Yup, just push down the white tab and pull the connector off.
09-23-2021, 03:37 PM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
If need be spray a little WD40 on it. Some times they get dirt inside and hard to squeeze. Or just squeeze it hard and wiggle it off gently.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
09-23-2021, 04:35 PM | #5 |
Yep, just a wee bit of WD-40 and squeeze and pull and twist gently, should just slide right off.
09-23-2021, 04:38 PM | #6 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
It also sometimes helps, to push IN on the whole connector before depressing the white tab, then pulling it off. The white locking tab can sometimes get wedged up against the shoulder it clips over, making it hard to push down and release.
09-23-2021, 05:10 PM | #7 |
Thanks everyone I'll try the wd40 tonight. It's co k d and damp and my fingers aren't working right
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
09-23-2021, 05:39 PM | #8 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
don't push the white part too deep as it can hang on the other side of the lip.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
