Old 10-21-2017, 08:22 PM   #1
Homeless Man
Homeless Life Chose Me
Homeless Man's Avatar
Drives: LS3 (sold 4/21)
Exclamation Help Car Wouldn’t Start Then Started When I Jumped It
Edit: Car is at the dealership now. They found out what’s wrong. Turns out the negative cable from battery and positive cable need to be replaced. Parts and labor $720 (the cables alone are over $400 he said). What do you guys think? Seem a bit hefty.
Ok so I’ve been having this problem for a while. The car has slow cranks when the engine is warm. I changed the starter and the problem was solved for like 2 weeks then came back. Also changed the battery. Recently on cold starts I started getting a clicking sound or sometimes 2 right before it cranks on cold starts and then the other day it wouldn’t start at all or even crank just continuous clicking sound when I turn the key. Hooked up the jumper cables and it started up (still clicked though). What do u think my problem is if it’s not the starter or the battery?
Also what’s weird is that the problem completely went away for a few weeks this summer and I even pushed my car hard multiple times to make sure it was nice and hot then turned it off and then started it and no slow cranks worked perfectly fine then back to the problem a few weeks later.
Video I took after jump starting it:
2011 2SS Coupe LS3 Longtube Headers/hi flow cats CAI dyno tune.
Pity a man in familiar places, who yet feels like a stranger.
Homeless Man is offline   Reply With Quote
Old 10-21-2017, 08:30 PM   #2
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Sounds like you've got a parasitic battery drain going on. But more detailed info about your car would help.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 10-21-2017, 08:33 PM   #3
Homeless Man
Added it. And how would parasitic battery drain cause it to have super slow cranks right after turning it off after driving for a while and then trying to start it again. At a gas station for example.
Old 10-21-2017, 08:46 PM   #4
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Bad alternator???
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-21-2017, 09:38 PM   #5
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Given you have long tube headers and the symptoms you've described, my guess would be your starter is getting 'heat soaked'. I would try a starter heat shield wrap. I had a similar issues many years ago when I put headers on my '77 Camaro; heat shield eliminated the problems.
Old 10-21-2017, 10:27 PM   #6
Spec
Drives: 2010 Camaro 1SS LS3
Double check that your air filter and TB are clean too. Wipe the gunk off the TB every 5-7k miles.
Spec is offline   Reply With Quote
Old 10-21-2017, 11:44 PM   #7
Homeless Man
I have a heat shield and the starter is also wrapped in one. It doesn’t make sense why would my car not start on a cold start and why is it clicking. And why did the problem suddenly go away for a few weeks?
Old 10-21-2017, 11:59 PM   #8
Welker2
Welker2's Avatar
Originally Posted by Homeless Man View Post
I have a heat shield and the starter is also wrapped in one. I doesn’t make sense why would my car not start on a cold start and why is it clicking. And why did the problem suddenly go away for a few weeks?
Didn't realize you already had the wraps. Given this, the fact your car started right up with a jump and if you replaced the battery at or around the same time you replaced the starter, my next guess would be a weak/bad alternator or a bad ground/positive cable that is not allowing your battery to fully charge when the car is running. This would account for everything working for a couple weeks after replacing the starter & battery. You should be able to get the alternator tested for free at your local parts store, I know AutoZone offers this service.
Old 10-22-2017, 08:26 AM   #9
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
#1 battery ground in trunk is just one weak bolt though a painted over tapped hole in the trunk that thing is cleaning it up may help a little, I read up on some posts as I have starter heat stroke sometime and if it gets to bothering me I will do a permanent jumper cable around the positive battery post using Zero gauge wire on the main wire from the battery as apparently the connection there can cause some resistance and its worked for a few people I read on another post not too long ago dredged up in the engine threads.
Other weak links could be grounds. Thats my best advice for you homeless, something I have yet to do as its raining, but a simple jumper around that terminal does make some sense...resistance= less voltage to starter and when its already hot even worse.....
Here Homeless you have had enough bad luck do a jumper and I bet it works....LOL me and BO planned on this..I will do it some sunny day..LOL
http://www.camaro5.com/forums/showthread.php?t=399658
Old 10-22-2017, 11:49 AM   #10
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Originally Posted by Roughwaterjohn View Post
It sounds like you have an intermittent bad ground, either on the negative battery cable or perhaps on the secondary ground wire (much smaller) from the engine to the frame. Did you perhaps remove one when installing the headers, or reinstalled it to another location that may be painted, and not a good ground?
A quick way to diagnose is to buy a short length of battery cable with a 3/8 hole flange on each end. Bolt it anywhere on the block that’s steel or iron, not aluminum, and to the frame, firewall / bulkhead or fenderwell. Just make sure both connections are to steel or iron and the paint is scrapped away before mounting to insure a good ground. If it fixes the problem but you don’t want the large cable in your engine problem, find the defect in your negative cable or auxiliary ground strap and you can eliminate the quick fix.
This^. That sound is a ground issue.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 10-22-2017, 01:04 PM   #11
JimmyRS
Drives: 2010 Camaro 1lt rs
My car was doing the same thing last month. Changed my alternator even though i got it “checked out” and they said it was fine and then the problem was gone. Haven’t had that issue since
JimmyRS is offline   Reply With Quote
Old 10-22-2017, 04:19 PM   #12
Homeless Man
Was yours slow cranking on hot starts?
Old 10-22-2017, 10:01 PM   #13
Olddudesrule
Resident nomad
If the alternator function is to recharge the battery and run the vehicles electronics after the car has started, and it's sufficiently charging the battery while the car is running, checks out otherwise, I would be checking all my associated grounds.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
Old 10-25-2017, 11:27 AM   #14
JimmyRS
Yeah very sluggish
