Old 03-27-2016, 02:16 AM   #1
Inferno19
Drives: 2011 2SS
Wheel/Tire Fitment Question
Yes, I know this has been discussed many, many times. However, I have gotten to the point where I have done too much reading and have read conflicting stories/views. Thus, I need help.
I purchased the following setup:
wheels -- MRR 228s: 20x10 with 23mm offset, and 20x11 with 43mm offset
tires -- PZeros: 275 40 20 and 315 35 20.
When I went to put them on today I noticed that the rear 20x11 takes up a significant amount of room. Hence my questions:
Does anyone have the same setup?
Has anyone had an issue w/ clearance, rubbing? I
Is a 20x11 too large for the rear?
Should I go to a 305, or is the 315 ok?
I do not want to cut/roll fenders or anything like that. The car is pretty much a DD.
Thanks for all your help. I truly appreciate it.
Inferno19 is offline   Reply With Quote
Old 03-27-2016, 05:19 AM   #2
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
The 1LE and ZL1 comes with 10" fronts and 11" rims in the rear, and I'm pretty sure the ZL1 comes with 315 tires as well. The wheels that come with those cars are the same +23/+43 offset.
That's a pretty popular combination as far as wheel sets go so you shouldn't have any issues at all.
terry_b is offline   Reply With Quote
Old 03-27-2016, 08:12 AM   #3
Caseyls3
Drives: 2011 Camaro SS/RS Convertible
The ZL1 has the same wheels but runs 305s. The 315s will fit perfectly - I have them and am lowered. No fitment issues
2011 Camaro SS/RS Vert - Jewel Red Tintcoat, 6M, 231/247 Comp Cam, Kooks headers, Borla ATAK, ATI under drive pulley, Richmond 4.10s, LS9 clutch, Hurst shifter, BMR Springs
Caseyls3 is offline   Reply With Quote
Old 03-27-2016, 01:28 PM   #4
Inferno19
Drives: 2011 2SS
Thank you both.
Old 03-27-2016, 04:18 PM   #5
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
How much are you lowered? Springs or coil overs?
Mods - GPI Tune (Rhino79), GPI SS2VVT Cam, GPI RodMod Intake, CHE Trunion Upgrade, Bo White Ported TB, Holley Fuel Rails, B&M Transmission Pan, JRE Trans Dipstick, Circle D 3600 Single Disc Converter, ADM CAI, ADM Scoop, ADM Trans Cooler, Kooks Headers, Solo Cat Back, Elite Catch Can, Z28 Grill, Z28 Aero Package; Z/28 Rockers, Z28 Flares & Diffuser, BMR 1" Lowering Springs, ZL1 Addons Splitter Guards, MRR228 Wheels, Eaton Tru-Trac, Hurst Roll Control.
Ashen 6.2 is offline   Reply With Quote
Old 03-27-2016, 04:19 PM   #6
Ashen 6.2
Ashen 6.2's Avatar
I also have the MRR228's with 275/315 combo with stock ride height. No issues at all.
Old 03-27-2016, 04:20 PM   #7
Caseyls3
BMR springs 1.25 in front and 1.0 in rear
Old 03-27-2016, 04:29 PM   #8
Ashen 6.2
Ashen 6.2's Avatar
Cool and thanks! I have been considering a BMR 1" drop for mine.
Old 03-27-2016, 04:30 PM   #9
68rssscamaro
Camaro: A Legend Reborn!!
68rssscamaro's Avatar
Drives: SOLD: 12 2SS/RS LS3 45th
Casey every time I see your posts the more i want your setup! Looks awesome....
[SIGPIC][/SIGPIC]
68rssscamaro is offline   Reply With Quote
Old 03-27-2016, 04:34 PM   #10
Caseyls3
Thanks I appreciate it - need some better pics soon !
Old 03-27-2016, 04:37 PM   #11
68rssscamaro
In other posts you mention the ride is a bit hard, but not overbearing-correct?
I am thinking I do something but undecided on the finish and style rim. The 21's I have have gotta go.
[SIGPIC][/SIGPIC]
Old 03-27-2016, 07:05 PM   #12
Caseyls3
It's definitely stiffer, but, put it this way, my wife has not yet complained about it riding too rough. I would imagine dropping down to 20s will probably offset the stiffness a bit.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
