12-24-2016, 05:51 PM | #1 |
Drives: 2013 Camaro ZL1 & 1979 10.5 Camaro Join Date: Jul 2016
How to run E85
Hey There Guys
Will just running E85 make anymore power? What do I have to change to be able to put E85 or 93 in at the pump? Thanks, Ed |
12-24-2016, 11:41 PM | #2 |
Drives: Fast Join Date: Mar 2015
E85 allows more timing, or timing to be advanced, due to it burning cooler and having a higher resistance to burn. E85 will always make a high performance engine make more power BUT it makes the biggest difference on high hp builds. So if you're just bolt ons, then it's probably not worth it, but if you're running tons of boost and/or a cam then E85 can gain you 70+ rwhp.
12-25-2016, 12:53 AM | #3 | ||
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
12-25-2016, 08:40 AM | #4 | |
12-25-2016, 10:37 AM | #5 |
Thanks for the replies everyone. Where is the best place to find the required items? Is there anyone selling everything in a kit?
Thanks, Ed |
12-25-2016, 10:57 AM | #6 |
Drives: 2009 ZR1 Join Date: May 2010
I skimmed the postings and didn't see it, but your tune will also have to be adjusted to make use of it.
Here is a kit: https://www.dedicatedmotorsports.com...t_p/zl1ffk.htm Buying that kit gets the support of one of the best LSx tuners there is -Dave Steck. The kit just gives the sensor, wiring, fittings, etc. If you do need the auxilliary stuff (injectors, pump, filter) here that stuff is: https://www.dedicatedmotorsports.com/category_s/361.htm |
12-25-2016, 01:12 PM | #7 | |
KaBoom1701
Mods:
12-25-2016, 01:45 PM | #8 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
Your also going to need injectors and more fueling. Expect to sink about 3 grand to do it right. The flex fuel sensor injector combo is, 1200-1900, and you will need the fuel pump system or boosted pump. The aux pump is 1200.
So parts wise your 2400 to 3100 in parts right off the gate. Figure another 500 or so in tuning. The system as it sits stock, does not have enough injector, nor pump to run a decent percentage of E85. |
12-25-2016, 10:18 PM | #9 | |
KaBoom1701
Mods:
12-26-2016, 12:35 AM | #10 |
"BEASTM*DE"
This is a valid point...With the simple mods I have I'm not concerned with any additional cooling mods...With a more detailed build this has to be a part of the equation, as well as, the intended purpose of the car, drag, track racing, etc... at what point would one need to consider upgrading the intercooler and/or other cooling options such as adding Meth...And that is when the price might out weigh the desire...
12-26-2016, 12:35 AM | #11 | |
What bothers me is if the percentage of E85 drops from a larger percentage of regular fuel, how is the timing pull compensated. At the track not a lot of E85 is on hand, so it will be diluted with a refill, or top off. Is it possible to base the timing advance curve, and total advance numbers based off of E85 content %? The timing pull temperature would also need to decrease back towards the stock setting. Is that based on the % as well? If not I would stick with a easily avail fuel if your road coursing. |
12-26-2016, 01:16 AM | #12 | |
"BEASTM*DE"
12-26-2016, 01:31 AM | #13 | |
12-26-2016, 11:45 AM | #14 | |
Not so much a difference between E85 to E70. In some states E85 availability is sparce. So it could be E85 followed by regular 91. Most road course tracks do not have E85. My understanding to take advantage of the combustion cooling effect from E85 that the temperature ceiling of IAT2 should be raised to a higher limit due to the fact that E85 has 0 effect on IAT2 temps. You could run cooler in combustion, but still hit the IAT2 timing pull temps at stock temp limit settings. If this is a hard programmed point and you need to fill up at the track with regular fuel, it could be a major problem pushing the car bard for 20 minutes at a time. The addition of regular fuel and a raised IAT2 limit is going to be a real bad thing. If it (IAT2) timing pull tracks between stock and a full E85% then it could work for the road course guys. Last edited by Nor Cal ZL1; 12-26-2016 at 01:00 PM. |
