Old 11-04-2018, 03:56 PM   #1
X-QQQ-me
Drives: 2012 black ZL1
Cylinder 6 out
Hey fellas Iím new here so bare with me. I had cylinder 6 go out and I pulled the plug on it. The ground electrode bent in leaving no gap in the plug. Iím assuming the worst here. So itís with a valve. Part of the piston, detonation, over rev , just seeing if anyone has had a similar issue.
I got a bore scope on the way to work today. When I get home Iím going to cross my fingers and see what I find in there.
What yíall think?
Pic of plug
X-QQQ-me is offline   Reply With Quote
Old 11-04-2018, 04:39 PM   #2
crazydave
crazydave's Avatar
Drives: 2013 Camaro ZL1 M6
What yíall think?
Pic of plug
More people may be able to help if you provide more details about you car. Mods, miles, when did you notice the issue. At 1st glance it appears that the electrode had the crap beat out of it and possibly melted i.e. lean run. Can you post a closer pic of the electrode?
2013 ZL1 CRT M6
__________________________________________________ ____________________________________
Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip.
Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60'
Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer.
crazydave is offline   Reply With Quote
Old 11-04-2018, 07:44 PM   #3
X-QQQ-me
2012 zl1 m6
39000 miles
Lingenfelter 2.55 upper
Ati 8.66 crank pully
Ati harmonic balancer
Ported super charger
Ported 93mm TB
17/8 LT headers
Cora’s exhaust
Bosch 1000cc injectors
Cai
Tuned on 91 octane
I noticed the days before it idled a bit rough then was fine. I smelt a bit of fuel that was more then usual as well. Then the day it happened it fired right up I let it warm up for a few min then was going to head to work. As I pulled on the high way it shuttered bad and lost power so I turned around and went home to get my truck.
Old 11-04-2018, 08:16 PM   #4
X-QQQ-me
could someone point me in the direction of a shop that is reputable with these cars. I was looking at RPM in North Carolina but that is a long way for me nearly 22hrs from Sioux Falls SD.
Thanks for any and all Info guys.
Old 11-05-2018, 06:24 AM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2014 ZL1
Could try Schwanke Engines in MN. I've at least heard of those guys.
2014 Red Hot #1503 | 629 SAE | RotoFab | 28% OD | 1-7/8 LT's | JMS BAP | ID850 | TR7IX | MSD Wires | Monster LT1-S Triple |
RobZL1 is offline   Reply With Quote
Old 11-05-2018, 08:37 AM   #6
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
I am not getting naked.
Be interested to see what the bore scope shows. Did you test compression or at least turn the engine by hand with the plug out to see if you can see anything?
Happy_Dan is offline   Reply With Quote
Old 11-06-2018, 03:11 PM   #7
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Mine did the same thing, turned out to be the tune and caused a detonation, both 6 and 8 cylinders had the spark plugs smashed and took chunks out of the piston edges, cause a scar on the #6 cylinder wall as well. Machine shop will be the best bet to know the real damage.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 11-06-2018, 03:40 PM   #8
X-QQQ-me
How did you determine it was a tune issue? That’s what I am thinking as of now in my ordeal.. what did you end up doing to fix it all?
Old 11-06-2018, 03:42 PM   #9
X-QQQ-me
Happy_Dan I seen some scuffs on the piston face but could quite tell if anything was loose in there.
Old 11-07-2018, 01:59 PM   #10
gsxrturbo
Drives: 2010 ss
why not excessive autosports in Sioux fall
gsxrturbo is offline   Reply With Quote
Old 11-07-2018, 03:29 PM   #11
X-QQQ-me
I talked to them the other day! I’m new to this area and wasn’t to sure where to start looking. I met with Joey there and he seemed pretty cool and knowledgeable. I’m taking the car there on the 26th. I’m planning for the worst and hoping for the best. Lol
How do you know of Excessive gsxrturbo ?
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
