Emblempros
Old 11-16-2018, 02:16 PM   #1
derieu
Broke College Kid
derieu's Avatar
Drives: 2014 Camaro 2SS RS 1LE
ZL1 4.10 Gear?
Can't find too much information, but does anyone make a 4.10 or 4.11 gearset for the ZL1 rear end yet?
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP
-Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing
derieu is online now   Reply With Quote
Old 11-16-2018, 03:30 PM   #2
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
Doubtful. It doesn't need more gear.
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 11-17-2018, 11:09 AM   #3
derieu
Broke College Kid
derieu's Avatar
I own a 14 SS 1LE that will be a track car, I am debating going ZL1 rear end vs a built truetrac SS rear end. The higher gear is useful in my case with my transmission ratios
Old 11-17-2018, 11:36 AM   #4
Kevlar382
Kevlar382's Avatar
Drives: '12 ZL1; '71 RS/Z28; '99 Vette Conv
i believe 4.10 wont fit in a ZL1 rear end but might in your SS. The ZL1 is a different, much stronger rear end. I think you have the same rear end as the Z/28 and you might be able to get 4.10 for that. Good Luck
Kevlar382 is offline   Reply With Quote
Old 11-17-2018, 11:44 AM   #5
Coz3z3
Drives: 2015 1LE
I found these on Yukon for the SS. Doesn't look like they make any ring and pinion sets for the ZL1 end.
https://www.yukongear.com/productdet...x?ProdID=11556
$515 at Summit
https://www.summitracing.com/parts/yga-24564
Coz3z3 is offline   Reply With Quote
Old 11-17-2018, 08:53 PM   #6
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Maybe you would be better off swapping the trans for an M10 that came in the stock SS.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 11-19-2018, 07:49 AM   #7
acammer
Back in the game
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
A 1LE and an SS are the same diff - yes you can run a 4.10. A 1LE will most definitely benefit from this ratio. Motive makes a good 4.10 gearset that a lot of the fast guys out there are using with good success. Add in a TruTrac and an LPE cover and you've got a pretty good diff setup.
It's a shame we don't have a 4.56 option, but the housing is just too small to make one of those work and stay alive. 4.56 with a MM6 (1LE) gearset in the trans, on a 28" tire, would be perfect for an all motor stick quarter mile car.
2011 2SS SGM - CAI, PTB, Rod-Mod and ported intake, GPI SS3 cam, AR LTs 1.875", X-pipe, high flow cats, cutouts behind the axle. 25% UPD, 169*F stat, EE catch can, Ideal Garage clutch master, seperate reservoir, Tick-Shift billet throwout support, Motive 4.10 gears, LPW Differential Cover, BMR Pro diff bushings, Pegasus Solid rear sub-frame bushings. Tuned at New Age Hotrods - 497rwhp.
acammer is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
