08-01-2019, 08:06 PM | #1 |
Drives: 2016 2SS Join Date: Nov 2011
A8 Quit Today
I was cruising at 60 mph in D and rpm spiked, I let off throttle, rpm settled, pressed throttle and nothing. I coasted into parking lot, popped hood, checked underneath-no fluid, nothing in engine bay. I ran diagnostics on Dash Command and no codes. 15,100 miles on car. I checked trans temp - 150 deg. Turned car off, started car and tried D, R, and manual. No go...
Any suggestions??? Ugh!
Who Dares...Wins |
08-01-2019, 08:19 PM | #2 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
My first guess would be that the pump failed (broken chain?), but I would expect that should throw a code.
08-01-2019, 08:48 PM | #3 |
Drives: SS 6 speed of course Join Date: Jan 2016
Is it making noise, maybe a shaft failed. bummer these A8 pretty strong.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
08-01-2019, 08:59 PM | #4 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I’ll leave this here, just in case...!
https://mxamotorsports.com/product/m...ho-spec-build/
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
08-01-2019, 09:00 PM | #5 |
No noise, a bit of a shudder then it quit.
Who Dares...Wins |
08-01-2019, 09:02 PM | #6 | |
Who Dares...Wins |
08-01-2019, 09:30 PM | #7 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
My crapped out of me 2 years ago...started with no shifting out of 1 st gear on the way to the dealer. I literally pulled into the dealers garage bays, they couldn't get it into D or R, $3000k in parts and labor that GM paid under warranty, basically was rebuilt.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered) 3800 Status - 10/13/15 (Built) 6000 Status - 12/22/15 (Delivered) |
08-04-2019, 04:12 PM | #8 |
It was the TQ converter and pump.
Who Dares...Wins |
08-04-2019, 06:09 PM | #9 |
What did you end up replacing the TQ converter with (stock or aftermarket)? Glad to hear you’re back up and running.
08-04-2019, 10:41 PM | #10 |
Thanks man. Stock replace and all covered by GM. The car is sold...
Who Dares...Wins |
09-07-2019, 01:25 PM | #11 |
Drives: like an old lady Join Date: Jun 2012
that escalated quickly.
2016+ camaro: everyone’s first car
10-09-2019, 04:05 PM | #12 |
Drives: Chevy Camaro Join Date: May 2019
