09-14-2011, 08:01 PM | #1 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
I want a racecar out of my camaro
MY CAR IS FULL RACE, NO STREET DRIVING
2010 SS M6 i do alot of drifting and i am starting to prepare my car for next season. i have a few questions, dont know if some are even possible. I want to remove the side airbags, because i don't want this to happen http://www.camaro5.com/forums/showth...hlight=airbags I want to disable the rear brakes while i am holding a button on shifter, i slight change from standard linelock. I want to disable ABS I want to increase the steering angle, but cheaper than blu808 parts http://www.blu808.com/Suspension_c_142.html I want to permanently disable the traction control and stabillitrac, nannies. but i dont want my brakes to suck like this thread indicates. http://www.camaro5.com/forums/showthread.php?t=171344 I dont want any warnings to appear in dash. i will be getting a custom dyno tune, and i am not sure what all the tuner can turn off. thanks for your help |
09-14-2011, 09:19 PM | #2 |
Winner
Drives: 2011 Camaro SS LS3 Join Date: Mar 2011
09-14-2011, 09:28 PM | #3 | |
knows 2 facts about ducks
09-14-2011, 09:38 PM | #4 |
wow i didnt realize how much a good tuner can do, and for the steering i mean the spindle part down on front end, to increase the lock angle from the wussy 31 degrees, i just was hoping someone came up with something else cheaper than 6,600 dollars, but i guess the demand is just too low.
09-15-2011, 07:09 AM | #5 |
Slow Turtle
I'll hit most of these up
I want to remove the side airbags, because i don't want this to happen http://www.camaro5.com/forums/showth...hlight=airbags Pull em on out, it's not hard. Your front airbags will no longer work, however, and your airbag light will stay on. You can remove the light from the cluster circuit board with a pin soldering iron. There are two long bags in the upper side panels, and two small bags in the seat sides I want to disable the rear brakes while i am holding a button on shifter, i slight change from standard linelock. Thats the exact same as a standard line lock, you'd just be applying it at zero brake instead of full brake. Remember, it's just a solonoid that shuts a valve in the brake line. If there's full pressure in the rear, it will keep full pressure. If there's none, there will keep none I want to disable ABS Unplug the abs sensors in the wheel hubs, or remove abs fuse. Simple. Youll have to remove the cluster light from circuit board to get rid of it, cant be programmed out. (bcm) I want to increase the steering angle, but cheaper than blu808 parts http://www.blu808.com/Suspension_c_142.html Cant help you here I want to permanently disable the traction control and stabillitrac, nannies. but i dont want my brakes to suck like this thread indicates. http://www.camaro5.com/forums/showthread.php?t=171344 If ABS is disabled, these are also disabled, as they are part of the abs system I dont want any warnings to appear in dash. Remove the leds, as of now, they arent programmable out of the bcm. i will be getting a custom dyno tune, and i am not sure what all the tuner can turn off. None of it, it's all BCM controlled and not pcm |
09-15-2011, 07:35 AM | #6 |
Drives: 2010 Join Date: Jul 2009
My comments inline in BLUE.
MY CAR IS FULL RACE, NO STREET DRIVING 2010 SS M6 i do alot of drifting and i am starting to prepare my car for next season. i have a few questions, dont know if some are even possible. I want to remove the side airbags, because i don't want this to happen http://www.camaro5.com/forums/showth...hlight=airbags You can remove the airbags pretty easily. I removed ALL of them from my car when we added the 10 point roll cage. Side curtain, seats (swapped in Race seats), steering wheel, and side passenger airbag. Removing all of them saves 33 lbs of weight. Pull the fuse under the hood to disable the air bag circuit. that gets rid of the annoying beeping every minute. We had to keep the brain for them in the CAN bus chain. It is located at the rear of the console. I want to disable the rear brakes while i am holding a button on shifter, i slight change from standard linelock. I want to disable ABS Never messed with the brakes or ABS on my car.. I need to stop quickly. I want to increase the steering angle, but cheaper than blu808 parts http://www.blu808.com/Suspension_c_142.html I want to permanently disable the traction control and stabillitrac, nannies. but i dont want my brakes to suck like this thread indicates. http://www.camaro5.com/forums/showthread.php?t=171344 Perminantly disabling the TC and Stabilitrak isn't easy.. It was done on my car "by accident". We removed Onstar, GPS, all Steering wheel controls when the steering wheel got replaced, airbags when the interior was gutted for the cage. TC and Stabiliteac never got "fixed" after we took it apart and re-assembled. I have no issue with my brakes whatsoever. The TC button in my car does nothing. I dont want any warnings to appear in dash. i will be getting a custom dyno tune, and i am not sure what all the tuner can turn off. thanks for your help I would assume you are stripping the car to remove un-needed weight? |
09-15-2011, 11:49 AM | #7 |
Yup i hate weight. I kinda wish i would have bought a cheaper car rather than pay for all this and then strip it all out
Thanks all of you that is a big help This should be a different car when im done |
09-20-2011, 06:46 PM | #8 |
Or you could have done it backwards by getting a stripped Camaro and adding the stuff you want starting with just $7,000.
http://jalopnik.com/5117896/gm-perfo...ite-new-camaro You may want to look into dedicated race pads instead of the Hawk HP+ pads. I would call Hawk and a couple other pad companies and see what they offer for drifting. Different pads have different bite depending on tepmerature.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
09-27-2011, 12:13 AM | #9 |
Everyone hit on what I was going to say already. Just like to see how everything works out when your done
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
Thread Tools | |
Similar Threads | ||||
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 42 | 12-22-2017 04:42 AM |
GT5 Camaro pics | brantley847 | Camaro Photos | Spyshots | Video | Media Gallery | 93 | 05-27-2013 08:35 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 106 | 10-19-2009 06:08 PM |
