Old 06-27-2018, 01:36 PM   #1
Hawayanzl1
Hawayanzl1's Avatar
Drives: 2014 Camaro ZL1
silver ZL1 wheels part # please
I am trying to find the part #for the front wheels for a 2014 ZL1. LMK
Hawayanzl1 is offline   Reply With Quote
Old 06-27-2018, 05:59 PM   #2
HDRDTD
Here is a photo of the numbers stamped into the front wheels of my 2013 ZL1. Hopefully the wheels are the same for 2014?
Old 06-28-2018, 01:41 AM   #3
VChula
SoCal C5 Family Member
VChula's Avatar
Drives: 1996 Z28 SS & 2014 ZL1
9599037 = Front
9599038 = Rear
Vance Chula -
1996 Camaro Z28 SS #1688
2014 Camaro ZL1 Coupe #1956
VChula is offline   Reply With Quote
Old 06-29-2018, 12:39 AM   #4
Hawayanzl1
Hawayanzl1's Avatar
Okay thanks for the part number. What i meant is that I am trying to buy oem ones and can not find a place to buy them brand new using that number. Lmk
Old 07-05-2018, 10:51 PM   #5
2Z's4me
2Z's4me's Avatar
Drives: 2013 Camaro ZL1, 2006 Corvette Z06
Try these links:
https://midwestwheelandtire.com/prod...lloy-wheel-rim
https://www.gmpartsdirect.com/oem-pa...-alloy-9599038
2Z's4me is offline   Reply With Quote
Old 07-06-2018, 08:38 AM   #6
hntrgthrs
hntrgthrs's Avatar
Drives: 2015 ZL1
Stupid question, but would the rear 5-spoke ZL1 wheels work on the front? Trying to plan out a true square set-up for when I replace tires and am curious if the 20x11s with 305s would work out front.
2015 ZL1 Coupe - Summit White | Stock (for now)
hntrgthrs is offline   Reply With Quote
Old 07-06-2018, 11:39 AM   #7
HDRDTD
I would expect 305's on 11" rims on the front would rub, but I haven't tried it to confirm.
Old 07-06-2018, 04:36 PM   #8
hntrgthrs
hntrgthrs's Avatar
Drives: 2015 ZL1
I'm curious, but I would think it would be close to working since doesn't the Z28 run the 11"s in front with 305s? I would assume the offset would be the issue; not the 11"/305s.
Old 07-06-2018, 09:49 PM   #9
HDRDTD
I was wondering the same thing, but I was thinking the Z/28 had 295's on all corners?
Just did a quick search on 2015 Z/28 specs and found this...…
305/30R19 102Y Pirelli P Zero Trofeo R
Notice the Z/28 rides on 19" rims rather than the 5th gen ZL1's 20"
Old 07-06-2018, 10:19 PM   #10
hntrgthrs
hntrgthrs's Avatar
Drives: 2015 ZL1
Right, I think it should be close to working on the ZL1. Granted, could also run the 20x10s from the front all the way around with spacers in the back (I think?) since they can take a max 305 tire.
Old 07-09-2018, 09:41 PM   #11
Hawayanzl1
Hawayanzl1's Avatar
Thanks for the link. Aloha
Old 07-15-2018, 01:30 PM   #12
2Z's4me
2Z's4me's Avatar
You're welcome!
