01-25-2021, 12:48 PM | #1 |
Engine gasket set
For the peeps building or will be building an engine. I ran across the Fel-Pro gasket set CS 9284
This kit even has the cam plate and fasteners! Around 135 bucks so for what all it has in it I think it's an awesome buy. All you need is head gaskets and you'd have almost every thing. |
01-25-2021, 12:53 PM | #2 |
Nice find & thanks for sharing Bo! How is the build going so far?
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
01-25-2021, 01:36 PM | #3 |
Delays keep happening but nothing that isn't manageable.
The shortblock is on the engine stand and ready for finishing up the assembly. |
