Old 05-27-2013, 08:26 PM   #1
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
How to launch my ZL1 at the strip
Sorry if this has been discussed already but I couldnt find anything. I just traded my 2010 modded SS stick for a 2013 ZL1 auto and am going to the strip this thurs for some shakedown runs. How should I launch? At first I will run with my street tires then later try out my DRs. What setting should I be in to do a burn out and also to launch? Paddle shift or leave it alone? Thanks for any advice.
mrvenicess is offline   Reply With Quote
Old 05-27-2013, 08:54 PM   #2
OldScoolCamaro
.....since you are asking, I'll give you the official rehetoric...<this stuff is in your owners manual, and in the sticky section on C5>. After starting your vehicle, press the far right switch on your center console next to the sport/tour switches. It's the stabilitrak switch. Press it twice, you will enter PTM mode. Once you see you are in PTM mode by visually viewing it in the DIC, < and two yellow lights will illuminate in the right instrument guage> toggle sport to the go up to level 5 PTM. That will say race mode PTM5 in the DIC. On the starting line after you stage, press the throttle to the floor and hold it there. The RPM will bounce off the rev limiter, and settle down to about 4,300 RPM. Once the last light yellow comes on the tree, lift off the clutch and go. You can keep your throttle foot matted to speed shift..that is ok.
Old 05-27-2013, 08:57 PM   #3
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Originally Posted by OldScoolCamaro View Post
.....since you are asking, I'll give you the official rehetoric...<this stuff is in your owners manual, and in the sticky section on C5>. After starting your vehicle, press the far right switch on your center console next to the sport/tour switches. It's the stabilitrak switch. Press it twice, you will enter PTM mode. Once you see you are in PTM mode by visually viewing it in the DIC, < and two yellow lights will illuminate in the right instrument guage> toggle sport to the go up to level 5 PTM. That will say race mode PTM5 in the DIC. On the starting line after you stage, press the throttle to the floor and hold it there. The RPM will bounce off the rev limiter, and settle down to about 4,300 RPM. Once the last red light comes on, lift off the clutch and go. You can keep your throttle foot matted to speed shift..that is ok.
It's an auto...
I wasn't going to comment because I drive a stick and have nothing useful to add, but I saw this above and it solicited a response, and "That Guy" in me has to put this....
My understanding, given that it's an automatic, is that you point the tires that-a-way, wait for the green light, and punch the gas
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 05-27-2013, 09:04 PM   #4
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
Does the convertible have that same setup. Just wondering I haven't tried it. Thanks
Candr3535 is offline   Reply With Quote
Old 05-27-2013, 09:13 PM   #5
2012-1822
2012-1822's Avatar
Drives: Black ZL1
I think so? Easy way to find out, go to your driveway, start the car, hit the button twice, so forth and so on. You'll see the PTM pop up on your info center between your tach and speedo if you have it. I don't know why you wouldn't. I think you are top speed limited, but I think they still want you to have a good drag car
Old 05-27-2013, 09:17 PM   #6
OldScoolCamaro
Originally Posted by 2012-1822 View Post
It's an auto...
...lol, I didn't see it was an auto, no biggie, but...since you solicited a response, that guy in me says if you wait till it's green to mash it you will be snoozing at the light and what's the point in drag racing then...
Old 05-27-2013, 09:22 PM   #7
OldScoolCamaro
...heres a previous thread on it...
http://www.camaro5.com/forums/showth...ight=ptm5+auto
Old 05-27-2013, 09:33 PM   #8
HDRDTD
The convertible does NOT have the PTM modes.
it's one of the differences between the Verts and the Coupes.
Old 05-27-2013, 09:39 PM   #9
2012-1822
2012-1822's Avatar
Drives: Black ZL1
I'm going to go with, that sucks. So what does the vert have, just a gas peddle and a clutch? Serious question, do you launch it like just in sport mode or something?
Old 05-28-2013, 07:58 AM   #10
All-American ZL1
Chevy Power
All-American ZL1's Avatar
Drives: 13 ZL1 M6 #123, '98 Jeep Wrangler
I take it you'll be at the bradenton motorsports park, I'll see ya there!
2013 #123, M6 2.38 upper, ID850, dynatech 1 7/8 headers, cats, X pipe, ADM CAI, 160 Tstat, Hurst line lock, tune by FSP
Sebring 2:39.20 MPSS
All-American ZL1 is offline   Reply With Quote
Old 05-28-2013, 08:25 AM   #11
mrvenicess
mrvenicess's Avatar
This Thurs!
Old 05-28-2013, 08:51 AM   #12
HashimAzzouz
Drives: 2011 2SS/RS IOM ~ 2009 Traverse LT
Really, didn't even thought about that!!!
HashimAzzouz is offline   Reply With Quote
Old 05-28-2013, 09:13 AM   #13
HDRDTD
Another difference is that the Verts are limited to 155mph due to the fabric top.
Old 05-28-2013, 09:16 AM   #14
HDRDTD
As far as I know, the Vert does have 'Launch Control' where you slam the gas peddle with the clutch pushed it. The car will then rev to and hold at a rpm (usually around 4,000rpm) depending on the time, then you just release the clutch and hold on.
This is the same thing my 2011 Vert had and it worked great.
I just haven't found the right time and place to try it.
Yet.
