02-15-2018, 01:10 AM | #1 |
Drives: 2017 2SS NGM Join Date: May 2012
5th Gen 45th tires on '17 2SS
Hi all,
Picking up my 2ss next week... excited to be back at home with the Camaro after 4 years with a SUV. I have like-new '12 45th 2LT tires (not rims). Are these compatiable with the 2SS stock rims (both rims are 20")? Both the '12 and '17 are 245F and 270R - just the two numbers following this are different. Not sure. Would be nice to swap the all-season tires with the performance for the winter months. Thanks! |
02-15-2018, 06:14 AM | #2 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
A 245/45-20 will fit the rim but will be to tall so you will get lots of rubbing, the 45 after the 245 is the height.
02-15-2018, 09:04 AM | #3 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
245/45-20
245mm is the tire width 45 is the aspect ratio which determines how tall the sidewall is. 20 is the rim size. A 245/45-20 tire is 28.68" tall. Here is how the math works out: - 245 (tire width) x .45 (aspect ratio) = 110.25mm - 110.25 / 25.4" = 4.34" (tire height per sidewall) - 4.34" x 2 (both sidewalls) = 8.68" - 8.68" + 20" (wheel size) = 28.68" The stock SS tires are different overall heights on each end, you will want to stay as close as you can to that for the speedo to be right and so you dont freak out the ABS and Traction control system. |
02-15-2018, 11:27 PM | #4 |
Thanks for the feedback, all!
So it's not recommended to use the 5th gen tires I have, correct? Does anyone have any recommendations for all-season run flats for the stock 2017 2SS rims? Thanks! |
02-16-2018, 01:27 AM | #5 |
Drives: 2016 Camaro 2SS, 2006 corvette Join Date: Mar 2016
ExCrystal try the BF Goodrich sport comp A/S. They are a good value for the money.
2016 Hyper Blue 2SS, A8, MRC, Ceramic white interior, NPP, Street Scene front splitter, 6LE side skirts, 20x10 and 20x11 Race star recluse wheels wrapped in MP4S.
02-16-2018, 03:23 PM | #6 |
Thread Tools | |
