05-06-2018, 02:02 AM | #1 |
Drives: 2021 Forte GT Join Date: Jul 2011
2014 Spring edition exhaust change
Hi All,
Anyone know if I can do a quad exhaust with the 2014 spring edition with the body kit it comes with? If so, any one have any recommendations?
If the whole world was blind, how many people would you impress?
Previous cars: 2014 V6 Spring Edition 2018 WRX 2022 K5 2022 Stinger |
05-06-2018, 09:25 AM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Just a quick google search, the Spring Edition body kit looks to be the same as the one on the SS, and the SS can accommodate the factory NPP. Obviously pictures can be deceiving, especially with no concrete evidence. I'd measure the opening and see if you can fit quad tips in it.
Before I had my NPP exhaust, these are the tips I used. http://tips.byethost4.com/dualpair.html?i=1 Just remember, if you do quad tips, your exhaust has to be modified slightly so that the tips exit in the correct location.
05-06-2018, 04:40 PM | #3 | |
Where did you end up getting the NPP from?
05-06-2018, 07:02 PM | #4 |
Honestly I bought it off of another forum member. NPP + Magnaflow 11386 is basically the same as the Magnaflow 11386 with a muffler delete, sounds excellent. Highly recommend. I travel a lot so the dual mode is important to me (I did the NPP in a box conversion also). Otherwise, I dunno. Maybe the MRT V2, magnaflow mufflers or just a muffler delete for your car? Those are my first suggestions.
Thread Tools | |
