Old 07-11-2018, 09:17 PM   #1
1 MODDED CAMARO
1 MODDED CAMARO's Avatar
Drives: 2013 CAMARO
Flowmaster Delta CAI
Has anyone installed one? Any feel of the difference or sound?
2012-15 3.6 LFX
1 MODDED CAMARO is offline   Reply With Quote
Old 07-11-2018, 10:39 PM   #2
denboy1
Drives: 2014 2ss Convertible
I did on my 6.2 and it really upped the noise level at full throttle. Not sure of any power gains as I did a dynosteve tune at the same time.
denboy1 is offline   Reply With Quote
Old 07-12-2018, 10:42 AM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
All intakes will net you induction noise (because you're removing the air box and intake tube silencer) and some horsepower. Think a net of 10-15whp normally. Enough to feel. If you throw an intake on, get an air scoop also. No sense in not.
DSX_Camaro is offline   Reply With Quote
