08-05-2012, 01:26 AM | #1 |
Window Auto up Feature
So I just drove about 1000miles from Texas back to Chicago after picking up my New 2012 Camaro Convertible. On the drive I started noticing how quickly those windows go up with the autoup feature. While that is very cool it started to make me think about what would happen if i mistakingly kept lets say a finger out the window while i turn them up . Can anyone tell me if the Camaro has a Saftey reverse function or anything like that?
08-05-2012, 01:39 AM | #2 |
Drives: 2012 2LT/RS TF3 Join Date: Nov 2011
Why not stick a finger in there and find out? can't hurt that bad right?
08-05-2012, 03:04 AM | #3 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Had it roll up on my wrist as I was waving to a passing camaro. After it gave me a good squeeze it went back down on it's own, like an elevator door opening after closing on an object.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
08-05-2012, 04:07 AM | #4 |
Don't Like it? Suggit.
Mine's pretty slow...
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
08-05-2012, 06:14 AM | #5 | |
Drives: 2017 2SS Join Date: Mar 2012
All cars with the "auto up" have that safety feature. Also, if you don't want to auto up feature to engage just barely push the switch (in either up or down position).
1996 Corvette - LT4
2017 Camaro 2SS 2019 GMC Sierra 2500 HD 2015 Harley Davidson Ultra Limited |
08-05-2012, 06:21 AM | #6 |
Drives: Eve - 2011 Camaro 2SS/RS Join Date: Apr 2012
Roll it up on your finger and see. Doesn't hurt too bad.
08-05-2012, 06:23 AM | #7 |
Drives: 2012 camaro Join Date: Feb 2012
08-05-2012, 06:25 AM | #8 |
Hoser Orange
Drives: 2010 2SS/RS Join Date: Jun 2012
08-05-2012, 06:27 AM | #9 |
08-05-2012, 07:51 AM | #10 |
~COTW 6/30/14~
Auto up?
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS BUILD TIMING CHAIN FAILURE TRANSITION FROM STOCK TO CAM VID |
08-05-2012, 08:16 AM | #11 |
Dave
Drives: 2011 Camaro SS - Black/CGM Stripes Join Date: Feb 2012
From the owners manual:
Express Window Anti-Pinch Feature When express-up is active, the window will auto-reverse if there is an obstruction or severe icing. The window returns to normal operation after the obstruction or condition is removed. If conditions prevent a window from closing and it continues to auto-reverse, the window can be closed by having the ignition in ON/RUN and holding the window switch up until the window is closed. Programming the Power Windows If the battery on the vehicle has been recharged, disconnected, or is not working, you may need to reprogram the windows for the express-up feature to work. Before reprogramming, replace or recharge the vehicle's battery. To program each front window, follow these steps: 1. With the ignition in ON/RUN, close all doors.
2. With the window partially open, pull the power window switch up until the window is fully closed. 3. Repeat step 2 on all remaining windows. |
08-05-2012, 10:28 AM | #12 |
~COTW 6/30/14~
Thanks Dave I will try that.
08-06-2012, 08:24 AM | #13 | |
Drives: GM Vehicles Join Date: Jun 2010
Express Window Anti-Pinch Feature When express-up is active, the window will auto-reverse if there is an obstruction or severe icing. The window returns to normal operation after the obstruction or condition is removed. If conditions prevent a window from closing and it continues to auto-reverse, the window can be closed by having the ignition in ON/ RUN and holding the window switch up until the window is closed. I hope this was helpful! Brandon Chevrolet Customer Service
08-06-2012, 09:37 AM | #14 | |
Drives: 2011 1LT Join Date: Mar 2012
All in the name of redneck science... |
