JUICEDMOTORSPORTS
Old 09-23-2014, 03:32 PM   #1
RGRCamaro
RGRCamaro's Avatar
Drives: 2011 Camaro 2SS
"Service Stabiltrak"
Hey guys,
Today when I was doing some driving on a "Private" road, I was flooring it and as I am in 3rd gear, nearing 90-100mph, I get the message "Service Stabiltrak" (Keep in mind I was driving with just T/C off, ST on) once this popped up I backed off the throttle and after a few seconds it went away. Can Acceleration alone set it off?
Should I be concerned? I have researched and found too many different answers as to why this message pops up. Maybe a sensor? I have also heard ECU?
2011 Camaro 2SS/RS LS3 M6 - 672rwhp/581rwtq - 91 octane tune
RGRCamaro is offline   Reply With Quote
Old 09-24-2014, 10:58 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
There are a lot of things that can lead to that message..unfortunately all you have told us is that you got a "service Stabilitrak" message while flooring it in third gear......if you have searched like you said you have....then you would know that that message can be produced by a lot of things....maybe some more details about your mods and tune would be in order. Or even how it was tuned.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-25-2014, 01:19 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Originally Posted by RGRCamaro View Post
Hey guys,
Yes you should be concerned.
Start by inspecting plugs and wires, a misfire will make the light flash.
Misfire can be caused by weak wires, cracked spark plug, low fuel pressure which caused lean condition.
Ted.
www.jannettyracing.com
Celebrating 33 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 09-25-2014, 01:20 PM   #4
CruisingSpeed
The Stealth Bumblebee
CruisingSpeed's Avatar
Drives: Black 2013 2LS
You completely climb a curb? I did and had that message.
KILLER BEEhttp://www.ferrarilife.com/forums/attachments/modern-v8s-360-f430/51795d1353344804-f430-yellow-calipers-imageuploadedbytapatalk1353344802.106093.jpg
CruisingSpeed is offline   Reply With Quote
Old 09-28-2014, 01:31 PM   #5
MonteSS
MonteSS's Avatar
Drives: 2010 1SS M6
I got this the other day at the track as well. I'll keep you updated
MonteSS is offline   Reply With Quote
