JDP Motorsports
Old 08-28-2015, 12:08 PM   #1
Irace16
Irace16's Avatar
Drives: 2010 1SS RS M6
Trunion or not to Trunion?
Trying to get all my parts lined up for my night fury cam and prc head install. Do I need to do the Trunion upgrade or what? Wife is getting annoyed at my recent spending so if I can avoid the extra $130 ish I will, but also don't wanna smoke this thing ,then she'll really be happy ....I think I just answered my own question...maybe
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Irace16 is offline   Reply With Quote
Old 08-28-2015, 12:15 PM   #2
Unreal
Drives: 2006 Z06
I would skip it. Worst case easy to do later.
Nick
Corvette Z06 -1200ish rwhp
Old 08-28-2015, 12:25 PM   #3
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2015 Silverado CC
I was told I didn't need it so I skipped it.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, Pedders Xa Supercar Coillvers, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 860whp 790wtq
760bowtie is offline   Reply With Quote
Old 08-28-2015, 12:28 PM   #4
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
Wives and Camaros rarely get along well. It's like having a mistress that always demands money, and the wife finds out.
Honey, I need new rims and tires... Ok
Honey, I need headers and a tune... Ok, wow, that wasn't cheap
I know but that will be it
uh... I need drag radials... .. eye roll. ... and a cam... door slams..
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 08-28-2015, 12:44 PM   #5
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
$130, yes good idea to wait till the needle bearings are scattered throughout the engine.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 08-28-2015, 01:26 PM   #6
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
There are multiple threads on this, and differing opinions. I did it, twice. Had a failure the first time, but I believe the stock rocker would have also failed.
I like the idea of it capturing the bearings in the event of a failure, others have said there isn't a big deal since the needles fall straight to the pan anyway.
Id do it again until I see a reason not to
Old 08-28-2015, 04:40 PM   #7
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
I do like the Brian Tooley trunion upgrade. While the bearings are probably the same as Comp, I can tell the trunion itself is different and the c-clips on the ends would keep any needle bearings from getting loose in the engine. I had to change mine because of the Comp failure, but if I had to start from stock I'd probably just go straight to the Brian Tooley upgrade and call it a day. YMMV
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 08-28-2015, 06:21 PM   #8
Rctreece
2013 Victory Red LS3 Vert
Rctreece's Avatar
Drives: 2013 SS/RS
I did it. Just dropped all that coin on everything else why not $130 for some more insurance? Lethal did all the work and I am very happy
Rctreece is offline   Reply With Quote
Old 08-29-2015, 05:47 AM   #9
avido
Drives: camaro ss\rs
I did it.
avido is offline   Reply With Quote
Old 08-29-2015, 07:58 AM   #10
Irace16
Irace16's Avatar
I like the captured needle idea , but also read that there are more failures with the aftermarket trunions opposed to the stockers...that's why I worry ...spend money on a part that could fail sooner than stock. This should be easier to decide dammit
Old 08-29-2015, 11:25 AM   #11
Bodywerks
Drives: 2015 2SS/RS/1LE
I'm going the che bushing route, given .654 lift and 460lb spring pressures. And because PRC heads prohibit the use of any other rocker option without machining.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 08-29-2015, 02:00 PM   #12
MightymouseSS
Drives: 2011 LS3
Stockers here as well. Shop where i had the cam installed said that it good but not a absolute must do. He recommended if the car was gonna see a lot of track use or constant high rpm then it would be a good idea but a weekend warrior not so much.
Stainless Works Headers
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Tuned by Southwest Speed
MightymouseSS is offline   Reply With Quote
Old 08-29-2015, 05:01 PM   #13
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
If you just feel like you have to trunion.....use the btr kit. We use it when the customer wants a trunion upgrade.
Rhino79 is offline   Reply With Quote
Old 08-29-2015, 05:39 PM   #14
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
How about a full rocker upgrade?
PerformanceHeartbeat Supercharger -BTR Stage 3 PD Cam -CHE Rocker Arms -Roto-Fab Cold Air -VMaxx TB -Elite E2 Catch Can -Prospeed HX -Squash Fuel System -FIC 1000 Injectors -EMP HX pump -Kooks LT's/Cat-less -Corsa 3" ZL1
Suspension1.25'' Front & 1" Rear Drop- BMR (Sway's, Toe Links, Trailing Arms, Front End Links, Upper Control Arm Bushings, Outer Trailing Arm Bushings)-FMT Solid Subframe Bushings
Brake's/WheelsPowder-coated Calipers-Goodridge Lines-Slotted and Dimpled Rotors-Hawk HPS Pads-OEM ZL1 10 Spoke Wheels (285 Front/315 Rear)
Nighthawk89 is offline   Reply With Quote
