Old 09-15-2015, 05:27 PM   #1
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
416 or Cam & Heads?
My SS is my DD and has almost 90,000 miles on it. I've got all the suspension goodies and Kooks headers and Magnaflow 3" cat-back, Ported throttle body. I want more power and would really prefer to go the forged route. The cost is the only thing holding me back.
I figure a 416 and install labor and tune would cost about $12K (correct me if I'm wrong), and ported heads and a cam (with all the other stuff--oil pump, timing chain, etc) would run about $5K (correct me if I'm wrong).
I started thinking even though my stock engine has 90,000 miles and would really need a head rebuild, trunion upgrade, etc, it runs great and doesn't use or burn any oil, it should be worth something if I sell it. I'm an old fart and seldom rev the engine over 5,000 rpm. I've maybe hit 6,000 rpm once or twice in 4 years. I believe that Grannie driving would change after installing a 416 with 480-500 rwhp.
I know there's probably not much of a market for an LS3 with 90,000 miles, but how much do you think I could get for the long block? Is there a reputable forged engine builder that might take my long block as a trade-in? Any suggestions on where I should get a quality forged 416?
I think I might be able to get between $2K and $3K for my complete long block. That whittles the $7,000 price difference down to $4 or $5K and would make my out of pocket about $9-$10K, which I think I could swing. What do you all think?
Thanks for your input.
Meh
My 5th is offline   Reply With Quote
Old 09-15-2015, 05:47 PM   #2
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
If I could choose I would go forged stroker vs heads on a 90K LS. You can do so much with a forged bottom later on. I have 93K on mine with the 2nd performance cam. Runs great, never burns oil and it's been cammed since 10k miles. I just think at 90K adding power has to have some impact on main bearings. Others may chime in and say they will last longer. Haven't seen much talk about mains and rings and how long they last on stock or mostly stock LS engines. Let's see what others think.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 09-15-2015, 05:53 PM   #3
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
If you're stuck on the other two options then I would say go 416...If you are thinking about it now, you're going to do it later...when you do it later you're going to have to put in a different cam at a minimum, possibly different heads depending on what cam goes in there you may want to mill the heads for compression or get different chamber sizes anyway.
You're probably correct on your long block selling price of 2-3k...maybe a little more.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 09-15-2015, 05:56 PM   #4
SNSSTR
SNSSTR's Avatar
Also, if you pull the engine to put in a 416, please do yourself a favor - Since your stock clutch has 90k miles, get it out of there, change the clutch to at minimum a mantic er2 and change out that stock slave cylinder. You're already going to be in there so there's no reason not to at that kind of mileage.
Old 09-16-2015, 07:45 AM   #5
Taco Time
Taco Time's Avatar
Drives: 2014 1SS
I don't know what things cost in Utah but I don't think I paid half of your estimate for my 417. I'd start looking up shops that build stroker motors. If you have one reasonably local to you that would be your best bet for trading in your block. I would recommend selling it outright. I'd also say use Craigslist instead of this forum to sell it. People on this forum told me my block was only worth $2500-$3k. I put it on craigslist and had it sold for $3500 in like two days. If you'd like to PM me I will happily walk you through everything I did and share what I learned. (Good, bad, and otherwise.)
^^^ Upgrade your clutch. I don't race and mine's almost toast.
Here's a few shops I can think of.
Texas Speed and Power
Florida Speed and Power (Fountain Race Engines)
ERL
HKE
I know there are more, that's just what comes to mind right now.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap|
Built by J-Rod.
Taco Time is offline   Reply With Quote
Old 09-16-2015, 04:39 PM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
if you can swing a 417 sell LS3 to someone who needs another 150,000+ more miles out of it. if not i wouldn't worry about putting a cam in a well maintained LS with 100,000 miles on it. lifters would have to be replaced though.
real ZL1 wheels 285/305 Michelin Pilot Super Sports, Pray ported IM/TB, EFI Tuning Flex fuel kit, American Racing Headers 1 7/8" long system w/ cats H pipe to Hurst Flowmaster NPP mufflers. Full 1LE suspension, with BMR adjustable sway bars and links, Hurst shifter
JCunningham is offline   Reply With Quote
Old 09-16-2015, 07:59 PM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
You should be able no problem with your engine to get a cam installed. You probably have at least 100 thousand more miles before time to worry about some compression test. I agree the lifters are toast so pulling the heads is required and you could like I have: gone cost effective with new GMPP ported heads that are only $1200. I got mine from Summit and switching the Springs would be that much easier with the heads off and you could really check out your bore.
A stroker will make more torque which is nice but not necessarily the easiest most cost effective way to make power as our cars are undercammed and can gain easy 75 h.p. from a cam swap and tune depending on how radical you want to go. I would also with the miles on your car want to change out the rocker arms maybe just for safeties sake as its cost effective preventative maintenance. Don't believe: look at the 525 hp ASA cam shaft crate engine...... same exact engine but tighter LSA cam with more duration and LESS lift than our stock cam at .525..........not .550.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 09-16-2015, 11:56 PM   #8
My 5th
My 5th's Avatar
Thanks for the input. One thing about modding--it never stops. I had also thought I would replace the clutch--probably with a ZR1 twin disk, and possibly go to a 3.91 pumpkin. I'll just have to see how much wallet is left after deciding on the motor.
Meh
Old 09-17-2015, 12:01 AM   #9
JCunningham
Drives: 2017 2SS M6
with a 416 your going to have more power then the SS diff can handle
Old 09-17-2015, 09:33 AM   #10
hazy
Drives: 2011 2SS/RS
not true. 416 here...stock driveshaft/diff/axles. Not a single issue. Do have an upgraded clutch, though...
I am, however, planning on a zl1 rear-end setup soon, as I'm hoping to SC my car eventually. The "problem" with the 416 is that you don't make super huge gains after the build (I'm at ~470whp/465tq), but when you start putting on power adders (SC/turbos/etc) the potential power you can make increases dramatically. THAT'S when you really need the upgraded driveline...
hazy is offline   Reply With Quote
Old 09-17-2015, 10:02 AM   #11
SNSSTR
SNSSTR's Avatar
I agree...stock SS diff will handle the power from the 416 just fine. Mine is.
Old 09-17-2015, 12:24 PM   #12
JCunningham
Drives: 2017 2SS M6
so far. 500 hp is about all its good for. after going back to read why its the limited slip and axles that fail in the 500hp range
Old 09-18-2015, 09:52 AM   #13
Jason 98 TA
Drives: Camaro
Are you doing install yourself? I think you can do heads cam & 418 for less than that.. Honestly probably even install under 12 grand.... A TSP long block would give you plenty of money left to have it installed & you'd have your stock long block to sell
http://www.texas-speed.com/c-760-376...ng-blocks.aspx
Jason 98 TA is offline   Reply With Quote
Old 09-18-2015, 06:40 PM   #14
My 5th
My 5th's Avatar
Right now I would probably have JDP Motorsports in Sandy do the labor and tune. I've asked them to see if there's a way I can have them do what I want.
I used to do my own wrenching when I was younger, but those days are way behind me now. In addition, my wife would never allow me to take over our small 2-car garage for the tear-down and install. Besides, then she'd know I was spending some $$$ on my mistress. That would not be healthy for me.
Meh
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
