05-03-2017, 08:09 AM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
$700 to spend on DD suspension. Want to be 1" lower.
Id like to drop the car just a touch but dont want a stiff ride over bumps. I think that means I shoukd use a progressive spring. Looking for Brand suggestions.
While I'm at it, i was planning to add better sway bars, but from what ive been reading on this forum, the pros say that should be addressed last. As there are far bigger problems with my stock 2011 SS suspension. If I go with an eibach prokit, 1 inch drop progressive spring, I should have about $450 bucks left. The Eibach Pro Plus drops the car 1 inch and adds both sway bars for $650. Is my $450 better spent elsewhere, or should I just buy the kit? NOT LOOKING TO PRESS BUSHINGS IN/OUT.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... Last edited by eLeSthree; 05-03-2017 at 08:25 AM. |
05-03-2017, 08:28 AM | #2 |
All I want from this upgrade is a slightly lower ride with the same feel, and maybe a little better steering feedback or stiffness. If i could get rid of the tracking that would be nice too. By no means do I expect a huge difference for $700, though.
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
05-03-2017, 10:58 AM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
You need to look at spring rates compared to stock ( I think there's a sticky on it), most aftermarket spring increase stiffness by 30+%. Im currently running 1LE sways and shocks and thinking about the DSE lowering spring set and rear subframe busing are in the work along with Z28 UCA bushings which are a unbolt/bolt operation. If you just want to look at lowering just do the springs and save your mod-money for another round down the road.
Orange Krush II
05-03-2017, 11:36 AM | #4 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
$400 will get you the JPSS Black Magic Rear Sway Bar. This thing is just animal. Dead flat through the curves and coupled with the stock SS front bar makes the car perfectly neutral in cornering. Going lower - you will probably get even better results in that respect.
There is an exhaustive post - think its called the Book of 5th Gen that does a deep dive into our suspensions. Long story short, a 5mm difference between the front and rear sway bars is the sweet spot in our cars. Using the stock front SS bar with the JPSS rear comes out to 4.5-5mm difference (factoring in not just the size but the strength difference of the front bar being hollow). I can personally attest to this as with the mods in my sig and recommended alignment I have already pulled 1.02G. There is more in her - I just ran out of corner. When you are ready, you can do the bushings and other things, but the only thing I would recommend besides calling Justice Pete is to either do everything that requires an alignment at the same time or get the Lifetime alignment from Firestone ($169.00) so you only have to pay for that part of it once. HTH, Sammy
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
05-03-2017, 11:50 AM | #5 |
CAR-DASHIAN
Just saw where you mentioned tracking - look into the JPSS Front Radius Rod Delrin Insert and Castor Locks. Castor Locks are cake to install.
This cured it for me. If you search "suspension" and "postnup", I did an exhaustive review of the JPSS products and alignment.
05-03-2017, 12:13 PM | #6 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
As you can see.....there are a lot of opinions. Sadly, when you start modifying, one thing begets another.
But, you are on a budget....and a lot depends on who does the work....you or a shop. Like you, I want to improve my cars handling without breaking the bank. I dont track....might hit the drag strip this summer. So, I think you arw on the right path with Eibach progressive rate springs and matched struts. Been a bit of discussion on if the front sway really needs upgraded. The rear sway is a must on the early year cars due to the inboard mounting. For me....Eibach springs and struts, ZL1 rear sway kit, upgraded front sway bar end links and a couple properly placed bushings and im done. Good luck.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-03-2017, 12:22 PM | #7 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
An effective and cheap upgrade would be to convert your rear to fe4 and add a zl1 away bar. After that z28 upper control arm bushings and solid subframe bushings.
As others said, get with JusticePete. Browse his 5th gen book and website.
More to come. |
05-04-2017, 01:31 PM | #8 | |
Drives: Camaro Justice Join Date: Jun 2007
If you can get past the look and focus on handling, the hands down biggest bang for the buck mod on a 2010 5th Gen is a telephone pole sized rear bar followed closely by Z/28 radius arms or my Billet Bushing Inserts. Next up would be upgrading to 1LE/ZL1/Z28 Toe links. These three upgrades will have you thinking you are driving a new and different automobile. |
05-04-2017, 02:04 PM | #9 |
CAR-DASHIAN
JP the Yoda of 5th Gen suspensions he is
Rides better than a lowered car and corners better than most; His rear sway bar is definitely a tree trunk!!! Check my sig - I have hit 1.02g so far. Even with the Pegasus rear bushings the car is still smooth on the highway. So glad my car has received JUSTICE!!
05-04-2017, 02:54 PM | #10 |
Drives: Race Car Join Date: Sep 2009
While some want/will Spend a lot to modify their cars. Other need to do so on a Budget especially if they want to keep their car on the Street.
This can be done easily on & within Budget Lowering Springs Cradle Bushing Inserts Trailing Arms SwayBars Toe Rods |
05-04-2017, 09:48 PM | #11 | |
Also, the delrim vs aluminum instert. Id like to keep it very streetable. Should i wait for the delrin to be instock again?
05-04-2017, 10:41 PM | #12 | |
Wait less than 24 hours for new pricing on the inserts Volume on the Billet Aluminum Bushings has been so strong we are going to eliminate the Delrin version and LOWER the price on the Aluminum version |
05-04-2017, 10:45 PM | #13 |
What the hell. No time like the present. Delrin is Dead. Billet Aluminum Radius Bushing Inserts are On Sale!!!
