Old 07-08-2018, 10:20 PM   #1
L6611983
Drives: 2010 Camaro 2SS
Adhesive
Any suggestions to removing pinstripe adhesive a quicker way, I just spent the last 2 hours removing it with WD-40.
L6611983 is offline   Reply With Quote
Old 07-08-2018, 10:47 PM   #2
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
they make a vinyl or pin stripe eraser wheel check auto parts.
Cyber/Orange10 is offline   Reply With Quote
Old 07-08-2018, 10:57 PM   #3
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
https://www.amazon.com/Remover-Stick.../dp/B00VFACQRE'
These things are awesome.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 07-08-2018, 11:39 PM   #4
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
Rubbing alcohol And No it Won’t ruin your paint.
Edelbrock EForce Blower, RDP custom grind cam with upgrades,Stainless Power Headers with HighFlow Cats, Stainless Power Retro catback, DSS halfshafts, CAI brand CAI, Tuned ON the Dyno by Steve at RDP. SLP rims,All vinyl stripes removed and painted on, custom hand painted pinstriping, Custom leather seats, Lloyds mats,windows tinted, Sparks emblems, Hurst Billit shifter, and too many small items to list. VDI Scissors doors.
splashlog48 is offline   Reply With Quote
Old 07-08-2018, 11:52 PM   #5
Rahnok
Fish Poop Aficionado
Rahnok's Avatar
Drives: 2015 2LS SIM
I use automotive GooGone. I usually just have to spray to remove adhesive residue, but for tougher areas, I spray it on a paper towel and let it sit on the spot for a while. 3M also makes an adhesive remover. Heat also helps.
Rahnok is offline   Reply With Quote
Old 07-09-2018, 06:25 PM   #6
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
Originally Posted by shibbs View Post
This right here is the best investment you could ever make to remove stickers, vinyl, or other adhesive from your car. It is amazing to see one working. There is also a segmented one that is a little more aggressive but wears away faster. Neither will hurt your car but they do make a mess shooting yellow powder everwhere so roll your windows up, not that I learned that the hard way or anything.
https://www.amazon.com/Whizzy-Wheel-..._&dpSrc=detail
Talladega is offline   Reply With Quote
Old 07-09-2018, 08:40 PM   #7
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Sticker Shock always worked for me. I used to buy them at Advanced Auto Parts many years ago. Never had a need for it now. Check into this link...
http://www.kleanstrip.com/product/sticker-shock
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 07-11-2018, 03:53 AM   #8
jimlem
Drives: 2013 Camaro 2SS RS 1LE
Cannot imagine anything resisting good ol' acetone.
jimlem is offline   Reply With Quote
Old 07-11-2018, 04:10 AM   #9
PJMZL1
PJMZL1's Avatar
Drives: 2015 ZL1
Goo gone works well.
2015 ZL1 M6
PJMZL1 is offline   Reply With Quote
Old 07-11-2018, 11:15 AM   #10
BLU DUCE
BLU DUCE's Avatar
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
+100
Old 07-11-2018, 02:21 PM   #11
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
When I worked at a Pontiac dealership we used a can of 3M. I’m willing to bet lighter fluid was in the same realm of it. It has an oil in but it will evaporate if left there. So lifhterfluid is good as it has oil in it. Alcohol will evaporate too fast. WD 40 is good too. Just have to let it sit. Take a shop towel, soak adhesive portion and start rubbing it.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 07-11-2018, 06:54 PM   #12
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
This.
Those wheels are awesome. It made removing the adhesive tape after removing the body side molding on my Suburban, Tahoe and Silverado effortless. Worked well removing 15 year old pinstripe tape on a Saturn too.
Low Saturn is offline   Reply With Quote
Old 07-12-2018, 06:17 PM   #13
gringo
gringo's Avatar
Drives: Camaro V6
WD-40 and a plastic razor blade. Otherwise, use the Eraser wheel with a drill.
gringo is offline   Reply With Quote
Old 07-15-2018, 11:19 AM   #14
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
For adhesive removal nothing works better than Rapid Tac Rapid Remover, used by most professional detailers.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
