Old 12-13-2018, 08:43 AM   #1
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
NightOwl Halo Replacement LEDs
Halo LED failing or out? See here!
https://www.camaro5.com/forums/showt...7#post10383497
sjmautoprod is offline   Reply With Quote
Old 06-24-2021, 06:33 PM   #2
sjmautoprod
Drives: '16 2SS
Just in case someone needs one or two!
Old 09-02-2021, 07:26 PM   #3
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Dang wish I came across this before I purchased Diode Dyamics LED boards. My ap is no longer working on my iPhone Xs Max and is no longer available in the App Store. I am in the process of installing these now with new bluetooth controllers and drivers.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 09-03-2021, 06:54 AM   #4
sjmautoprod
Drives: '16 2SS
FYI, we can convert other controllers to be PnP with NightOwl systems.
We also have our own controller family now that can be PnP. It can run addressable LEDs, too.
Old 09-03-2021, 12:47 PM   #5
davesnever
davesnever's Avatar
Drives: 2010 Camaro 2SS
That's probably the best way to go, stay away from app driven controls and use a physical controller instead. I have had my halos and controller for a bout 7 years now and still good as new. Remote is RF so you don't need line of sight to work and is good up to 50 meters.They do have an app if you choose to use as well but the remote is so much easier.
http://www.ltechonline.com/html/en/p.../LED/M-Series/
I am using this set exactly
https://www.ebay.com/itm/14360905118...4AAOSw5IZeaYtf
davesnever is offline   Reply With Quote
Old 09-03-2021, 04:49 PM   #6
SummitWhite11
Drives: 2010 2LT/RS
Sent PM
2010 2LT/RS
Old 09-03-2021, 05:11 PM   #7
SummitWhite11
Drives: 2010 2LT/RS
Is this used with the WIFI that is included with the original NightOwl system? This is new to me since I purchased the car from someone else who already had this system installed.
2010 2LT/RS
Old 09-03-2021, 11:39 PM   #8
davesnever
davesnever's Avatar
They have no relation to the NightOwl system. The LTECH package includes a controller module and remote which operates everything. It can control any RGB or RGBW led system. I installed halos in my headlights and fog lights as well as grill lighting. Sjmautoprod has stated if you are looking to get rid of the NightOwl controller(brains) they can supply you with their own controller which would be plug and play with your system, meaning the wiring and LED's would stay in place and just the controller would be swapped out. I think NightOwl went out of business and alot of people have had problems with those systems so a controller swap would make the most sense. I still prefer a controller with a remote control, I don't want to control my lights with a phone app but that's just my preference.
Old 09-04-2021, 11:46 AM   #9
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Sjmautoprod is your ticket for a plug and play set-up to replace the Nightowl modules, if need be. Trust me on this one. I'll get you the info, if you email me. I sent you a pm.
chef-beavis is offline   Reply With Quote
Old 09-04-2021, 05:11 PM   #10
davesnever
davesnever's Avatar
Oznium sells these too without the plug if you know how to solder.
Old 09-05-2021, 08:21 AM   #11
SummitWhite11
Drives: 2010 2LT/RS
I don't know much about soldering but pretty sure I could learn. Just don't have much time on my hands for that right now as I work for USPS. Want to get the car fixed up and get it out on the road again. I want to be able to use my new Diode Dynamics kit with the new RGBW LED boards I purchased. If I need a new module to get it to work then I am willing to do that as long as it's plug and play. I am just surprised Diode Dynamics did not mention that I would need the module. Only suggested I needed the LED Boards, Drivers and bluetooth controller.
2010 2LT/RS
Old 09-05-2021, 08:25 AM   #12
sjmautoprod
Drives: '16 2SS
That is all you need, except for the fogs/DRL that may be connected.
Old 09-05-2021, 08:26 AM   #13
SummitWhite11
Drives: 2010 2LT/RS
So the module is not needed? Did you get my email yesterday with the additional pics?
2010 2LT/RS
Old 09-05-2021, 09:32 AM   #14
sjmautoprod
Drives: '16 2SS
Yes, replied today.
