03-14-2016, 01:43 AM | #1 |
Drives: 2012 camaro SS silver ice Join Date: Mar 2016
How do you remove the high wing spoiler
I bought my 2012 camaro SS stock with the high wing but I want to taking it off to get it painted anyone know how to take it off? Thanks
03-14-2016, 07:24 AM | #2 |
I didn't know a "High wing" was stock on a 2012 Camaro. Anyway, I would open the trunk and remove the plastic plugs holding the trim in place. You may then see access holes in the trunk lid where you can loosen some nuts and remove the wing. Maybe... that's how my 2013's spoiler was mounted.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
03-14-2016, 08:28 AM | #3 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
Since that spoiler mounts farther onto the trunk you will have to open the trunk and pull the liner off the trunk lid and the hardware should be visible.
USMC 1980-1990
My other toys are Harleys Last edited by MCSarge; 03-14-2016 at 10:36 AM. |
03-14-2016, 11:11 AM | #4 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
the spoiler has a wire loom passenger side of the car where it connects to reverse and license plate lights. disconnect it. if you remove gray carpt on back you'll see their are holes where the spoiler mounted and you can use a socket to remove the 4 bolts that hold it on. some shops also used 3m tape. they also didn't come stock, but alot of dealers would option it after they got the cars on lot, or alot of previous owners added it in the early 2010's.
2011 Victory Red 22/RS
Forged 418 Ls3 from Texas Speed, LSX heads from Texas Speed, Tick Turbo cam, Jakes/PCM/Billet 4l80e, 3200 Stall converter from Circle D, DSS 750 hp axles, DSS aluminum driveshaft, stock 3.23 gears, TSW Wheels Front 20x10 Rear 20x11.5, Fabberage Twin Turbo Supercharger Killer kit with Upgraded Turbos, Squash Dual fuel pump, Full BMR Suspension/bushings, Holly High Rise intake manifold, ID1300 Injectors, Megan Coilovers, PCM of NC plug and play trans kit. HP/TQ TBA |
Tags |
1ss, 2ss, high wing spoiler, l99, ls3 |
