Old 05-17-2019, 01:05 PM   #1
Slickcas
Drives: 12' 2SS/RS LS3 IBM
MT Spokesman SR front tire press?
On the Mickey Thompson sportsman SR 28X6.00R18LT Front runners what are some you running for tire pressure?
On the website it says for max load 1650lbs @95 psi.
Did a quick search did not find anything relating to this tire.
Slickcas is offline   Reply With Quote
Old 06-10-2019, 09:25 AM   #2
Slickcas
Called MT. For the 12 Camaro at 4000 lbs. Was told to run 65psi
Old 06-12-2019, 02:06 PM   #3
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
running the Sportsman 28x6x17 and at 40psi they are soft and tend to wear the edges of the sidewall. Will try again with more pressure tonight and see if this makes the difference. I was just worried about popping the bead by putting it too high, but if they advised 65... I'll try 45 to start and move up as needed.
2011 Camaro 1SS
Whipple Supercharged street monster
Aries240SS is offline   Reply With Quote
Old 06-14-2019, 03:19 AM   #4
GODZL1A
GODZL1A's Avatar
Drives: 2015 ZL1
I run 52 in mine
GODZL1A is offline   Reply With Quote
