Old 07-19-2015, 01:53 PM   #1
jlight
jlight's Avatar
Drives: 2015 Camaro LT
PA Law and Catalytic Converters
This is probably the wrong section so sorry.
Is anyone familiar with Pennsylvania Law, specifically Dauphin county, regarding catalytic converters? PA law is really goofy and confusing. I'm planning to eventually modify the exhaust system on my 2015 V6 and I was thinking of replacing the stock cats to less restrictive, better airflow cats. I'm not sure if to pass emissions testing I need the stock cats, or just any cats. I know some counties in PA don't even require them to functional. They'll pass just as long as they are there.
Anyone know?
jlight is offline   Reply With Quote
Old 07-19-2015, 02:08 PM   #2
motorhead
That county requires emissions testing. If it passes with aftermarket cats you will be fine from people I know in that area. I'm lucky to live where testing is not required. So I don't have first hand experience with this.
Old 07-19-2015, 07:21 PM   #3
Top Off
Drives: 2012 LS3 1SS/RS Vert
General rule of thumb is as long as it passes the emissions test you are fine. Could a tech theoretically do a visual check and know it is not stock and fail it, yes.
Top Off is offline   Reply With Quote
Old 07-22-2015, 08:51 PM   #4
chevyss69
Drives: 2011 2ss/rs
It's all visual. You'll be fine..
chevyss69 is offline   Reply With Quote
