![]() Drives: 2018 Camaro 2SS Join Date: Nov 2013
Reduced Power Message
Alright, I have a 2010 Camaro SS/RS L99. Problem occurred while cruising down the highway when i got a reduced power message come across my dash. The car started misfiring EXTREMELY hard and eventually lost all power. I started the car again and kept misfiring but there are no leaks, no smoke, and no burning smells. Gave it a little gas to creep to a parking spot (with some gas, misfires went away but not completely). I left it alone for about 5 minutes, started it up again, and the reduced power message went away but check engine light remained. The car is completely stock with the exception of a ported throttle body. Can somebody please help?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
Go to auto zone and get the codes pulled. Once you have the codes, you'll be able to track down the problem.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
See this post sounds just like your problem ...turned out to be a bad throttle body http://www.camaro5.com/forums/showthread.php?t=332212&highlight=Cable Also, there was a problem with a loose positive battery cable in the trunk on '10-'11 SS that caused REP condition, not sure if misfires too. A TSP was created and dealers fixed. Check out the forum for "loose battery cable". Maybe you just have a bad battery as that will cause REP condition, again not sure if misfires too? My bet is the throttle body ...how long after you installed yours did you start having the problem? Post a follow no matter what once you find the cause. Last edited by camguynj; 07-25-2015 at 08:54 AM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
I agree with reading the codes. For less than $50 bucks, autozone et.al. will sell you a code reader. No garage should be without one these days. It helps point you in the right direction.
Tags |
check engine light, misfire, reduce engine power |
