11-27-2020, 08:57 PM | #1 |
Drives: 14 and 15 SS's Join Date: Feb 2018
FS: Fore Triple Pump Level 4 system with all the extras!
I am selling my Fore Triple pump Level 4 system. I will include all the extra stuff I added to this system to make it what I consider complete.
This system includes; -10 feed -8 return, all PTFE Upgraded larger filter with SS element for E85 Triple '274' pumps Factory fuel pressure sender installed after the filter. I will include the sensor and the wiring so you don't have to make a harness like I did. -10 feed to y block and -8 to each rail -8 out of rail to fuel pressure regulator and factory GM flex sensor installed on the return line out of the regulator. I will include the flex fuel sensor and the wiring for it. Honeywell switch I have included a screenshot of how this system is configured from Fore. It is over $2600 from them not including the little extras. By incorporating the factory fuel pressure sensor I maintained live fuel pressure reporting to the ECU. This took a couple tweaks to the FPCM Module with HPTuners but I will be happy to share that info with you. It worked really awesome. This system will fit a SS, G8, Caprice, 5th Gen Camaro and 2nd gen CTSV Price: $2000 Condition: Very Good Location: Minneapolis, MN
Bolt-ons!
12-03-2020, 06:08 PM | #2 | |
Drives: 2012 ZL1 Camaro Victory Red Join Date: Jan 2013
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
12-03-2020, 06:13 PM | #3 | |
12-03-2020, 07:45 PM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I’ve seen it over 1500 with 1700cc injectors
12-04-2020, 09:50 AM | #5 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Bump for an honest seller.
[what the hell is he up to now... going mechanical?]
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
12-11-2020, 10:03 PM | #6 |
Drives: 12 camaro ss Join Date: Apr 2016
1500?
12-14-2020, 06:08 PM | #7 |
Drives: Whippled Camaro Join Date: Oct 2016
I’m interested in buying system for a friend text or call 205-603-53two3 or (205) 937-4703
12-15-2020, 08:55 PM | #8 |
Drives: 2013 Camaro 2SS Inferno Orange Join Date: Apr 2015
02-01-2022, 07:30 AM | #9 |
I assume this has been sold?
