12-26-2014, 11:43 PM | #1 |
Ghost Ryder Z
Drives: 2018 Nightfall Gray ZL1 Join Date: Jun 2012
All Season tires for ZL1
Need a good all-weather tire to put on my ZL1. It is a daily driver that may see some slightly spirited driving and may ride by a drag strip once or twice. Mud and snow will not be an issue in the least. I live in SC so winter is very mild. I want to still drive on the pretty days when the temps dip into the 20-30 degree range. I had a set of vredstein tires on my SS and they were great. They could be noisy but preformed excellent in rain suggestions please
12-27-2014, 12:02 AM | #2 | |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
I've had the same questions and everyone suggested Continental Extreme Contact DWS In 275/40/20 and 315/34/20. It is a great all season tire and every time this topic arises it's the recommended tire.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
12-27-2014, 06:12 AM | #3 |
Drives: 2012 Inferno Orange SS Join Date: Apr 2014
+1 on the DWS. Great tire, although they're a little heavy compared to other tires in the same category. Another recommendation would be Toyo Proxes 4 plus, but you'll find they are less common. I've owned both, and will go with the Toyo's with my next tire swap
12-27-2014, 08:02 AM | #4 |
Pilot Super Sports A/S
12-27-2014, 08:28 AM | #5 |
Drives: on order black 2010 2ss Join Date: Mar 2009
12-27-2014, 11:27 AM | #6 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
01-02-2015, 11:25 AM | #7 |
Brewmaster
Drives: 2013 ZL1, 2015 Tundra 1794 Join Date: Jan 2011
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...
holy sh*t...what a ride!" |
01-02-2015, 12:45 PM | #8 |
01-13-2015, 01:54 PM | #9 |
Drives: 2014 CRT ZL1 Join Date: Jun 2013
I found that the MPSS are still generally better at 40 - 50° than the DWS.
The DWS are very good for AS, but are a huge drop from the MPSS. If you do not drive in snow, and have minimal 20 - 30° days, maybe stay with the MPSS all year.
ZL1 Camaro - Worlds Largest Sports Car
Road King - Not Garage Queen |
01-13-2015, 02:34 PM | #10 |
Drives: 18 Camaro ZL1 1LE (WILSON) Join Date: Jul 2009
Is there a temp requirement for the MPSS like the OEM GY's, do not drive below 40 degrees? I would like a tire I can drive on sunny days even though it is 30 degrees out. With the OEM GY's you cannot drive the car if weather is below 40 degrees.
01-13-2015, 03:18 PM | #11 |
ZL1 Pilot
Im running PSS 315's on the rear (summer tires). Grip is not good for aggressive driving in the cold. They spin like crazy when you step on it a little. But not as bad as the goodyears. Driving in wet mode in the cold works very well tho. No spinning......
I dont believe they will crack like the goodyears. My old goodyears have cracks all over them
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
01-13-2015, 03:30 PM | #12 |
I would say a good all season tire is the Conti DWS, the Michelin PSS everyone is mentioning is a great tire, but with the amount of power the Zl1 puts down and weather getting cold they do loose traction.
275/40/20 315/35/20 |
01-14-2015, 08:29 AM | #13 |
Drives: 2015 ZL1 Black #100 Join Date: Oct 2014
+2. I am running this setup and you do get pretty good traction. I can tell the tires are at their limits when accelerating hard, but so much better than driving on the bricks that came on the car.
01-14-2015, 11:56 AM | #14 |
Drives: 2014 Crystal Red ZL-1 Join Date: Apr 2013
I just put on the DWS 275 40 and 315 35 setup. Drove today in 23 degree weather with a half inch dusting of snow with no drama whatsoever. Better traction in the snow under decent acceleration than the stock tires on dry 45 degree pavement. I will put the wheels with the stock tires back on when it gets around 70 degrees. Ride is nice, much quieter. Rear tires look massively wide.
Thread Tools | |
