Old 10-10-2020, 05:27 PM   #1
Whoomba
Drives: 2024Camaro 2SS CE Convertible
Floor mats
In 1999 I bought some Lloyd floor mats for a truck I had then. They lasted forever. They were thick and quality. So when I came time to get mats for the Camaro better than the factory ones I looked up Lloyd. I thought I got the same level I bought way back but no. They aren’t much thicker than the factory ones and the backing is already disintegrating. You guys have any suggestions for the next set?
Whoomba is offline   Reply With Quote
Old 10-11-2020, 02:16 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Not sure what you're looking for exactly, but check out https://www.weathertech.ca/en/ if you haven't.
KillboyPowerhead is offline   Reply With Quote
Old 10-11-2020, 05:40 PM   #3
Whoomba
Hey, with the top acting the way it is, I might need those kind. I was looking for carpeted.
Old 10-11-2020, 05:50 PM   #4
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Drives: 2011 Camaro SS/RS
I have had Floyd Ultimats since 2012. They are still fine but the "SS" in the center is separating from the floor mat. Unnoticeable unless you take them out to clean and its really only a small section. I am ordering new Ultimats with a personalized word from autoanything.com I put them in my cart and left them in it the other day. Today I received an email with a code for $10 off. They have a coupon code "Fall2020". Together these brought my cost from $154 to $120. Just the front mats.
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS
BUILD
TIMING CHAIN FAILURE
TRANSITION FROM STOCK TO CAM VID
Maxspeed is offline   Reply With Quote
Old 10-13-2020, 04:44 AM   #5
BRZN
BRZN's Avatar
Drives: 2012 1LT
I've the carpeted Lloyd Matts in my GTO that's not driven much, but have the Weather Techs in the daily driven Camaro as well as our other vehicles. The Weather Techs hold up well and do a great job at protecting the OEM carpet underneath. Carpeted matts will wear much quicker than the composite (plastic or rubber) ones.
BRZN is offline   Reply With Quote
Old 10-13-2020, 07:10 AM   #6
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
Show=Lloyds
Go=weather techs
SIM GhostrdrZ is offline   Reply With Quote
Old 10-14-2020, 07:51 PM   #7
Whoomba
Show but wipe your feet first.
