#Camaro6
BeckyD @ James Martin Chevy
Old 02-01-2021, 11:39 AM   #1
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
THROTTLE BODY ADVISE NEEDED!
I have a set of 2" catless headers going into a stock suitcase. A 14% lower pulley spinning a stock blower. A RotoFab Big Gulp. JRE will remote tune it.
My last problem is I can't decide on the TB. I have a NW 103, but that has to wait until next winter for the Maggie 2650. I'm leaning towards a LT5 TB with an adapter. But still, JRE, Soler, Pray, Katech, or who? What do you guys think.
MartinLe is offline   Reply With Quote
Old 02-01-2021, 11:45 AM   #2
ZLE dude
Drives: '18 ZL1 1LE
JRE sells the LT5 TB w/ adapter. Soler works well also. Haven't had a Katech or NW but I'd assume similar. If you're getting tuned that certainly helps no matter which one you go with.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 02-01-2021, 11:47 AM   #3
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Katech
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 02-01-2021, 12:06 PM   #4
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Why don't you just use the 103 you have?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 02-01-2021, 12:09 PM   #5
20Bluezl1
Drives: 2020 Zl1 A10 Riverside Blue
I'm having the same issue on a deciding which way to go. I currently have a soler TB that is 87 that is ported to 91 from them .I still have it brand new in box never used.
I'm going to have Jannetty to do a tune and not sure if I just get JRE LT5 or get Soler TB that is 95mm ported to 100mm. Not sure if it would be to much air what do you guys think?
https://www.solerengineering.com/gen...ors/se9871-100
20Bluezl1 is offline   Reply With Quote
Old 02-01-2021, 12:34 PM   #6
thegoat
Drives: 6th gen
If you open the snout with porting on the supercharger I’d run a bigger Tb otherwise run the 87
thegoat is offline   Reply With Quote
Old 02-01-2021, 12:44 PM   #7
20Bluezl1
In Jannetty JRE package he runs the 95mm TB and he doesn't do any porting of the blower. Does the 87 to 95 or 100 have no impact on HP?
Old 02-01-2021, 12:49 PM   #8
thegoat
Drives: 6th gen
Everything that we’ve seen shows no gain of the 95tb if it eventually necks back to 87mm when compared to a well ported 87mm.
Old 02-01-2021, 12:54 PM   #9
20Bluezl1
So the Soler 87mm ported to 91 is fine for a non ported S/C
Old 02-01-2021, 01:23 PM   #10
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Ask Ted J what TB to get since he will remote tune your ZL1! He can advise you.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
LT4Greg is offline   Reply With Quote
Old 02-01-2021, 02:38 PM   #11
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
watch this video at the 21:00 mark to see if the TB is important for PD blowers.. I used a 112mm you went with 2" headers why not stay with the plan to make everything as efficient as possible and work the blower less.. Big TB, ported heads, ported blower, 5 inch intake.. 2 inch headers.. you will make more power and if that's not your goal you will make your power level with a few less psi and rpms which is always good.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 02-01-2021, 03:34 PM   #12
20Bluezl1
So what I understood from the video is you can put bigger TB to get as much air as possible and tune it to whatever the car likes.
I always believed to big of a TB is not good because there is so only so much air that you can use and to big will choke the car.
Sorry if I don't make sense
Old 02-01-2021, 03:58 PM   #13
gtfoxy
Drives: '21 Wild Cherry ZL1
It only needs to be so large, or flow enough, as not to have vacuum between the TB & the rotors.
gtfoxy is offline   Reply With Quote
Old 02-01-2021, 04:21 PM   #14
thegoat
Drives: 6th gen
This is 100% true but only if the blower is ported because it’s 87mm in there. I think you’re saying the same thing? The key is to increase the entire intake path even in the snout of the supercharger
