08-28-2021, 09:11 PM | #1 |
Drives: HBM ZLE Join Date: Aug 2017
Check headers before install
Have been chasing an exhaust leak. Tried 2 different gaskets as well as copper spray on the second gasket. Finally took the headers off and realized the flange was warped. Well known brand. I Should have checked before install, lesson for next time. Hopefully I can save someone from the same headache
08-28-2021, 09:47 PM | #2 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
That sucks. Shit happens, hopefully the mfg is taking care of it!
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
08-28-2021, 09:51 PM | #3 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Which manufacturer? Could help someone else out if we know which one to look for.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
08-28-2021, 09:54 PM | #4 |
08-28-2021, 10:08 PM | #5 | |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
Sent from my moto g(7) power using Tapatalk
08-28-2021, 10:18 PM | #6 |
Remflex Gaskets
08-28-2021, 10:20 PM | #7 |
Thanks, I have high temp gasket maker that would probably work but I'm most likely gonna have it decked
08-28-2021, 10:29 PM | #8 | ||
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Cosmetically they might look nice. So just be sure to check fitment regardless of the brand. Perhaps it would be a good idea to always check in general. Casually looking them over is always a good idea. Sure you might think they're fine because they are a well know company. Popular companies do have issues too. |
08-28-2021, 10:34 PM | #9 |
Like I said, I won't throw anyone under the bus.
It what it is, just have to deal with it, although those remflex gaskets do look promising. Thanks again Wuiquen |
08-28-2021, 10:42 PM | #10 | |
08-28-2021, 10:44 PM | #11 |
Casually speaking it isn't throwing anyone under the bus. You're not lying or making things up or exaggerating or adding to it. Nobody is out with pitch forks. But it might be a good idea for people to know in case this might be a bad batch they have. That way if people know to look for it then they might save themselves some headache from getting it all installed and then having to remove them. Especially if they have a shop do it and even more so if they have to cut up and/or modify the existing exhaust to make it fit. Someone could be out thousands of dollars and have their car sitting for days or weeks while they're trying to get another set. If they know to look for this then all that can be avoided. Again, it isn't throwing anyone under the bus. But if you don't wanna name them then that is your choice. I just hope nobody ends up in a situation where a shop is charging them extra money to remove the headers that were just installed and then install a completely different set.
08-28-2021, 11:07 PM | #12 | |
08-29-2021, 04:30 AM | #13 |
Drives: 2017 ZL1 Join Date: Apr 2020
Worthless post I'm afraid
2017 ZL1 M6 Silver Ice Metallic
08-29-2021, 06:33 AM | #14 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
