Old 04-21-2014, 03:44 PM   #1
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
160° Thermostat
Who has put in a 160° Thermostat and did it make that big of a difference? My ZL1 is currently stock and wanting it to run at least a little cooler this summer. Is it worth the effort and money (little cost on both ends). What does your temp usually run at after putting one in?
cybercoaster is offline   Reply With Quote
Old 04-21-2014, 06:18 PM   #2
BeachBum
Drives: 2012 (ZL-1) #468
I Too Want To Change To 160 Degree Thermostat - I've Been Told It Will Trigger A Sensor If I Change
BeachBum is offline   Reply With Quote
Old 04-21-2014, 06:26 PM   #3
TOYMARO
TOYMARO's Avatar
Drives: 2011 Camaro SS/RS 2SS
TOYMARO is offline   Reply With Quote
Old 04-21-2014, 06:26 PM   #4
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I did it when I put my blower on. No sensor issues.
newagemuscle is offline   Reply With Quote
Old 04-21-2014, 06:36 PM   #5
Unreal
Drives: 2006 Z06
My opinion is lower thermostats don't do much. It will make the car heat up slower but once it is open it won't be any different than a 180 or 190, or whatever stock is.
Nick
Corvette Z06 -1200ish rwhp
Old 04-21-2014, 06:46 PM   #6
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
Stock thermostats are 185 degrees. GM's position is that this is the optimal temp for performance. You would be better off looking to get better cooling from your fans/radiator, since the thermostat only controls the lower temp, not the higher temps.
Apex Paul is offline   Reply With Quote
Old 04-21-2014, 06:51 PM   #7
Baer383
Baer383's Avatar
Drives: 2013 ZL1 Ashen Gray
I'm making 754 rwhp and kept the stock thermostat instead of the 160 degree.
It is not needed in these engines!!!
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience.
754 RWHP 747 RWTQ 93 Octane
http://www.camaro5.com/forums/showthread.php?t=347243
Baer383 is offline   Reply With Quote
Old 04-21-2014, 06:52 PM   #8
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
Agreed 100% to all.
Bye bye, Bumblebee!
Old 04-21-2014, 08:06 PM   #9
newagemuscle
Philippians 4:13
Mine came free with my CAI 4 years ago. I had it sitting here so I decided to toss it in when I had the top off my motor for the blower. On these cars I can say I have not noticed much of a difference. However, on my LT1 it was a noticeable difference. Also, when I had my mustangs back in the day they always seemed to make a difference.
Old 04-21-2014, 08:35 PM   #10
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2012 CTS-V coupe
Good for 1/4 mile racing, but won't help you much on a road course. As already stated once it's open, it's open. Cheap enough mod though.
cvp33 is offline   Reply With Quote
Old 04-21-2014, 09:56 PM   #11
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
All a 160 degre thermostat does it make the engine take longer to come up to temp. This increases engine wear since all the tolerances are off. Also reduced oil life, Fuel economy also suffers as does emissions.
If the motor never really comes up to temp (lots of short trips), It also causes acid and moisture to form in the oil leading to sludge which could lead to engine damage.
http://www.tuneruniversity.com/blog/...l-temperature/
http://www.bobistheoilguy.com/motor-oil-102/
Effects from low temp thermostats on engine and oil life:
http://www.bobistheoilguy.com/forums...t&Number=50382
BigBlock69RS is offline   Reply With Quote
Old 04-21-2014, 10:03 PM   #12
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
geez...not this topic again. The "160 thermostat" that is being sold is more like 178. In old small blocks it really meant 160°.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:04.53 VIR Full 11.08@126.52 1.76
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-22-2014, 06:22 AM   #13
GenF-GTS
Drives: none
it's actually not 178 it is 160, i have put an SLP one in a cook pot with a laser temperature sensor and it starts to crack open at about 152 and is near fully open at 160 at about 162 it is 100% open.
This is taking the temperature with the laser pointed directly at the thermostat on a hot plate in boiling water.
It also retracts and closes up in a similar fashion temperature wise.
GenF-GTS is offline   Reply With Quote
Old 04-23-2014, 01:47 PM   #14
cybercoaster
Thanks all
