03-14-2018, 09:40 PM | #1 |
Drives: 2014 corvette Join Date: Oct 2016
Boost a pump adding power ?? What am I missing.
I also posted this on the HP tuners fourm.
Ok car is a 2013 zl1. Upper 2.4 pulley id1050x injectors.. tap headers.. no cats...tr7ix plugs cold air intake. Ok so before "JMS boost a pump* my AFR was pretty stable. 11.4-11.5. But fuel pressure would go from 65psi to 44 by 6k. Power felt good.. so I thought.....pulled strong. So I added the "JMS". And here is the "off" part. "Abadzl1* is doing my tune. We expected my AFR to go rich as fuel pressure is now steady at 65. But it stayed 11.5. But Holy Crap!!! the power increase. It pulls so hard and smooth through out the RPM band. It feels like a completely different car. How does making fuel pressure steady add hp? What do I not understand. ? |
03-15-2018, 06:02 AM | #2 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
You were running 1050's on solely the stock fuel pump?
03-15-2018, 06:09 AM | #3 | |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
03-15-2018, 06:14 AM | #4 |
Drives: Nil Join Date: Sep 2017
Proper fuel atomization. Injector spray is as designed at the target PSI, same quantity, different quality.
03-15-2018, 06:35 AM | #5 |
Yes I was running stock fuel pump but the id1050x... duty cycle before at wide open throttle at 6000 RPM was about 62% now it's 50% but a 10% drop...
03-15-2018, 08:01 AM | #6 |
Bingo.
03-15-2018, 12:16 PM | #7 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
I have said for years (to myself mostly) that they run out of fuel and hp not just lean out and melt. That's why people say they may or may not need a fuel pump voltage booster because they just leave a little power on the table.
When I first finished my car I had it on a dyno without the JMS plugged in. The car dynoed fine and power was less than expected at 600 whp. Then the car did 10.8 at 129 which for a convertible is pretty impressive on 600 whp. I am sure it was more once the JMS was plugged in.
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
03-15-2018, 12:27 PM | #8 | |
It seems like you're saying it's ok to run on a stock pump with 1050's and 600+ rwhp. I don't think the op was running 10.8 at 129. Running out of fuel at wot can be catastrophic. I think $1k (BAP) or $4k (Fore pump and rails and 1050's) is cheap insurance to avoid that catastrophic failure. A rebuilt LSA will certainly cost more than that. Just saying: I would not advise running 1050's w/o an auxiliary fuel system of some level. |
03-15-2018, 12:40 PM | #9 | |
2013 ZL1 CRT M6
__________________________________________________ ____________________________________ Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip. Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60' Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer. |
03-15-2018, 01:13 PM | #10 | |
Drives: Fast Join Date: Mar 2015
ABADZL1 knows what he's talking about, I'd trust him. |
03-15-2018, 01:53 PM | #11 |
All I can say is I am amazed. The car felt like it picked up some power after all the mods... but still felt closer to stock feel it didn't really feel like what I added I got a big benefit from.. and always felt like from 4500 RPM on up the power kind of planed out... it was still pulling but didn't have that hard pull fill to it..... It feels like I added a hundred shot of nitrous to it in all reality no jokes aside the car feels so different.
03-15-2018, 07:43 PM | #12 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Bryan 2018 ZL1 M6
