#Camaro6
BeckyD @ James Martin Chevy
Old 12-12-2017, 07:48 AM   #1
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Concerning this launch issue . . .
Originally Posted by crazydmc View Post
Be careful of any "expectation" of the Launch Control.
there is no "system" (i.e. Torque management, Traction Control, etc) that controls how the clutch is engaged. That is up to the driver.
so if you have Traction Control enabled while attempting an aggressive launch, if the tires start to spin, the only option the "system" has is to cut power... i.e. feels like bog. I drive in "Competitive Mode" to avoid this Bog..... it is up to me if my tires spin or not.
If you have Traction Control off, then you as the driver can adjust engine power vs engaging the clutch (i.e. slipping the clutch) just the "right amount" to achieve maximum acceleration. Trying to achieve this with Traction Control enabled could be very frustrating I would think.
If the Camaro had a "Launch Control" that actually operated the Clutch FOR YOU, then I would blame the car.
jmho
If this was 100% a mechanical setup with no electronic control/intervention at all (throttle and ignition especially), I'd agree.
But with electronics involved it's at least theoretically possible to adjust engine power to suit the available traction independently of how the clutch is operated. IOW, doing what you might have done in the past with the throttle assuming it was something other than floor it and side-step the clutch pedal.
And anything mechanical that is controlled at all by computer programming needs the calibration to be correct for the use.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 12-12-2017, 07:56 AM   #2
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
All Launch Control does, is employ an artificial Rev limiter so you are able to build revs and have the throttle mashed. Whatever happens after you dump the clutch is traction control.
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
