11-08-2017, 07:20 PM | #1 |
Drives: Camaro SS Join Date: Feb 2014
Kooks off road vs high flow cats
Is there a major sound difference between the 2? Pros and cons of each.
11-08-2017, 07:41 PM | #2 |
Drives: 2004 Ford Mustang Cobra Join Date: Aug 2015
I can't speak specifically for Kooks but I had Solo hf cats and switched to BBK off road pipes. It's way louder, in a good way. If you have to worry about emissions or inspection then keep the cats. As long as you have mufflers the sound isn't too outrageous.
You will also need a tune to take of the check engine light, assuming you don't have headers. |
11-09-2017, 12:41 AM | #3 |
Drives: 2010 Camaro2SS/RS Join Date: Mar 2016
No emissions in Iowa. Ditched original cats for off road pipes with LT headers. Sound difference in incredible. Tune out the rear O2's and youre good to go.
11-09-2017, 04:59 AM | #4 |
I’m running the solo Mach XC, is for a convertible.
11-09-2017, 11:40 AM | #5 |
Drives: 2004 GTO & 2005 GTO Join Date: Mar 2014
I've had both. Sound difference is pretty minor. It's louder catless, but only at WOT, and only slightly louder. The more noticeable difference is the tone, which is a bit raspier without cats, and the smell.
11-09-2017, 12:52 PM | #6 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
They sound and perform basically the same. The smell is maybe the only difference. That depends on tune though. My experience has been people look at off road to save money, then use the other possible things (louder/more power) to justify.
11-09-2017, 01:46 PM | #7 |
Honest answer thank you!
11-09-2017, 05:25 PM | #8 |
Started#gottalovethatblue
High flow cats take some of the rasp out of the sound of the exhaust. There's negligible performance difference and catless midpipes smell of unburned fuel. As Maryland Speed said, often times people go with off road pipes to save money over high flow cats.
11-09-2017, 08:31 PM | #9 |
GPI Sales Consultant
Biggest sound related difference is rasp - your cackles and pops will be "sharper" catless than even with a highflow cat. Overall volume is pretty similar, but there is a definite difference in tone.
Got a question about a GPI product? Feel free to shoot me a message! |
11-09-2017, 10:38 PM | #10 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
I can get mine to do some fairly loud backfires/decel pops that'll make peeps duck and cover...lulz...
11-10-2017, 05:30 AM | #11 |
11-10-2017, 08:12 AM | #12 |
old school chevy rodder
One little tidbit of information though; shops can be fined 10,000$ per occasion of removing cats on a car so equipped and you may of course find some who does it but I guarantee you if you ever get a exhaust fix it ticket for being too loud and have to retrofit in cats afterward the smell you tolerate and the thought in your mind of the money saved not getting high flow cats...well that will be overcome most likely with some money for the ticket.... If it ever happens, and the cost of adding them in if not having to return to stock in some places, I am lucky they allow headers in Oregon for stock exhaust replacement.
Many alter their cars with the muffler delete also which can in some places be illegal as its all in the law. Old cars I always did just a collector flange to the exhaust, some places make their "off road " pipe to resemble a high flow cat...and that would be to fake out a cop getting nosey..... being that I am old yes I have been pulled over several times over the decades with varied cars with headers.....I always had mufflers though and made the exhaust go behind the rear axle.....And if necessary used Monza tips. Rasp and smell both go up with out cats, legality goes up with them and fresh air...
08-27-2018, 08:30 AM | #13 | |
08-27-2018, 09:04 AM | #14 |
You can't tell a difference between high flow cats and stock cats? Maybe it's just a V8 thing, but I'm absolutely floored that you couldn't tell a difference. Update us after going back stock and let us know if you'd just gotten used to the difference or if there really wasn't anything different in your experience.
