10-11-2018, 08:12 PM | #1 |
Shifter question
My phone won't let me search on this site for some reason so I'll just ask it.
I toasted my clutch this year so since I need to replace that I'm debating about installing a mgw shifter while the tranny is down, so my question is how much better is the mgw shifter vs my factory hurst shifter? Is there a big enough difference to justify the cost
Cai intake and a few other mods😎
10-12-2018, 09:39 AM | #2 |
Drives: 2010 Camaro Join Date: May 2014
A very subjective question. I love my MGW.
I’ve never seen a used MGW for sale, but I’ve seen a few Hursts. If you were swapping from a standard shifter I’d pick an MGW because it edges out the Hurst, but since you already have the Hurst I’d stick with it. The MGW isn’t THAT superior over the Hurst to justify the swap. While the MGW might be better, I doubt you’re trying to shave .001 seconds off whatever times you’re seeking. |
10-12-2018, 11:57 AM | #3 | |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates Last edited by dreksnot; 10-12-2018 at 07:18 PM. |
10-12-2018, 06:24 PM | #4 |
Yes, but you know me I go crazy with research, well most of the time anyways
10-13-2018, 09:04 AM | #5 |
Drives: 2010 Camaro 2ss Join Date: Feb 2017
I have an MGW in my car and my buddy has a hurst in his. He says that my MGW is much shorter. I love my MGW
2010 LS3, American racing long tube headers, vararam intake, SLP Powerflo exhaust, DSX flex fuel sensor, ID 1050x injectors,BTR stage 4 cam, dual valve springs, hardened push rods, McLeod Rxt, Ram hydraulic clutch adjuster, MGW shifter, Strange engineering S60, 4.10 gears, 4” gforce driveshaft, gforce outlaw axles, BMR trailing arms, BMR toe rods, BMR outer trailing arm bushings.
10-13-2018, 10:07 AM | #6 |
Just to f@ck with you, jk nope me and Dreksnot talk in another group, but I wanted more opinions/thoughts, searching the internet you hear good and bad on the factory hurst shifter.
10-13-2018, 10:08 AM | #7 |
Thank you for your opinion, looks like I need to just pull the trigger and order a mgw
10-14-2018, 07:45 AM | #8 |
Drives: Black camaro 2ss 45th Join Date: Jan 2018
I had one in my 2010 and when it got totaled stuff was to mangled to get it out. So when my clutch goes out on my current one, which feels like will be soon, I’ll be putting an mgw in. Would never do that install again with the trans in the car
10-14-2018, 08:29 AM | #9 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
I have had 3 shifters in my car. Factory, MGW, and Factory Hurst.
The original shifter worked fine. Long throws, quiet, crappy baseball knob. The MGW shifter with their "Race" knob is an amazing setup. Nothing else like it. Short throws, nice "click-click" between gears. Made me drive a little more aggressively, made slightly more noise under load as compared to the GM shifter. The GM factory Hurst with the MGW Race knob is what I ended up with. Short throws, fits the hand perfecty, quiet. Sold my used MGW for good money to a forum member. MGW is amazing but it just does not solve a problem for me. I still hit all the gears, stay quiet, used money for other things. The Race knob is a MUST have though. Feels perfect, fits the stock boot and looks like it was factory. Hope this helps. |
10-14-2018, 10:42 AM | #10 |
Your using the mgw race knob, and if so which race knob did you go with?
10-14-2018, 07:17 PM | #11 | |
'69 Owned Since '79
10-15-2018, 09:56 AM | #12 |
Cool thank you for the info and pics
10-30-2018, 05:44 AM | #13 |
Drives: 2010 Camaro SS RS Join Date: Jul 2017
MGW wants a firm selection of first gear, guest drivers, techs can easily find third and stall. Second to third is a nice springy snap, the rest just flows with practice.
Kooks LTH, Haltech CAI, cam, tune, MGW shifter, HRE FF01 wheels
