12-21-2018, 09:42 PM | #1 |
Drives: 2014 Camaro ZL1 Join Date: Dec 2018
CHeck Engine light Code P219B Cause ?
The code is an air-fuel imbalance bank 2. From the research I have done on possible causes I have not found any vacuum leaks, exuast leaks, wiring, hoses or anything obvious. This 2014 ZL1 only has 6000 miles on it. I do have a freeze frame of the event but I am not sure how to read it, to me the most interesting data is the difference in voltage between O2 sensor 1 bank 1 and O2 sensor 1 bank 2 and the long term fuel trims for both banks, here are the readings:
O2 sensor 1 bank 1 voltage 0.435 O2 sensor 1 bank 2 voltage 0.115 Long term fuel trim bank 1 7.8 % Long term fuel trim bank 2 4.7 % My question is could the bank 2 O2 sensor #1 be going bad ?, any help with this would be greatly appreciated. |
12-21-2018, 10:19 PM | #2 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
That code means one cylinder on that bank requires significantly more correction to get to commanded lambda than the other cylinders in that bank. I believe the o2s1 needs to pass a function test before the p219 will set.
If you already looked for leaks, it could be an injector issue, spark issue, or some other random thing that is causing a cylinder to be off. You mention a freeze frame- what logging software do you have? Can you monitor pulse width or misfire or anything else? If you can log enough to figure out the problematic cylinder, you could start swapping components between cylinders until your problem moves to another cylinder, perhaps
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
12-22-2018, 11:55 AM | #3 |
Drives: ZL1 Join Date: Mar 2018
12-24-2018, 05:26 PM | #4 | |
12-24-2018, 05:28 PM | #5 | |
12-24-2018, 06:10 PM | #6 |
Drives: 2014 ZL1 Join Date: Jul 2016
Let us know what it turns out to be
DB |
12-24-2018, 11:59 PM | #7 | |
fo'shizZL1
Yes, the ltft's show that fuel is being added, but same deal- they don't really tell you much as a snapshot in time.
