01-15-2019, 04:20 PM | #1 |
Change spark plug wires w new headers?
Whats your opinion on changing to new spark plug wires at the same time new headers are being installed? if I can get better spark with improved wires it makes sense to me but does it make that much of a difference?
01-15-2019, 05:30 PM | #2 |
Instagram: Sangstah
It wont make that big of a difference power wise but will help with the added heat the new headers will put out. I went with Taylor 409 wires and they have been great with the heat. My JBA powercable ended up cracking on the rubber sleeve from the heat.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-15-2019, 05:54 PM | #3 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
Yep my Jbas cracked as well. Now I have MSD Super Conductors and they are great.
01-15-2019, 08:42 PM | #4 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Installed headers 6 years ago, still using original wires.
01-15-2019, 08:53 PM | #5 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
No, it won't make any difference. Leave the old wires for now. If you have a situation where you burn a wire on a header, you can identify and rectify the situation before you pay good money for a good set of wires. The protective wire boots that RDP sells work well if you do have an issue with a wire to close to a header tube.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
01-15-2019, 09:16 PM | #6 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Stock wires are just fine.
More to come. |
01-16-2019, 06:33 AM | #7 |
Drives: '14 BRM 1LE 2SS/RS Join Date: Nov 2017
Stock here as well, I just bought some $5 boot protectors off of ebay for added insurance.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC |
01-16-2019, 01:23 PM | #8 |
i just did LT header with HI flo cats and xpipe. because the guys were already there for the headers, they suggested to do plugs. i agreed and good thing, my car was around 40K and the plugs looked very used. i have a 2015 SS and is a daily driver. i went with PCM of NC wires with heat socks. i didn't do it because of performance but i spent the money for better and since the shop was in the same location it was kill two birds with one stone kinda situation. i also put in NDK iridium plugs.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
01-16-2019, 01:25 PM | #9 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Stock wires; headers fitted 3 years back - no issues, haven't heat-wrapped the pipes or anything.
01-16-2019, 01:55 PM | #10 |
Drives: 2014 2SS/RS Join Date: Jan 2018
I did headers, plugs, and heat sleeves on the wires.
2014 2SS/RS LS3/M6
01-17-2019, 03:23 PM | #11 |
I appreciate all the info, thanks!
