11-04-2014, 07:42 AM | #1 |
Mast Black Label or TX Speed PRC Heads?
Just like the title says. I've been doing some reading on each of these heads but I'd like some input from people who've used them before.
Mast heads would probably be the 255cc and TX Speed are the 260cc version. My car is a bolt-on car with a night fury cam (mods in signature). I want whatever is going to give me more HP gains.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap| Built by J-Rod. |
11-04-2014, 09:34 AM | #2 |
Drives: 14 Camaro 1LE,328i, and some Hondas Join Date: May 2014
There is also the GMPP heads, and the trickflow genx 255 heads. Best bang for your buck is the GMPP heads. The Mast black label heads will make the most power, but they're about 3k.
11-04-2014, 09:39 AM | #3 |
I haven't written those off yet and I am aware of the price difference, but right now I'm leaning towards black labels or the TX Speed PRC heads.
Taco's 2014 SS
11-04-2014, 09:59 AM | #4 |
Both will be plenty. I run PRC heads with no issues. If I had a ls3 based motor I would do the trick flows IMO.
Nick
Corvette Z06 -1200ish rwhp |
11-04-2014, 11:53 AM | #5 |
Drives: Camaro Join Date: Apr 2009
From a stock casting stand point your talking less than $1000 easily for cnc ported heads exchange. That will be a hard thing to beat for the $$$$!!
If your willing to spend the extra $$ for aftermarket casting then the PRC 255 & PRC 260 is hard to beat. They used altered valve angles & locations for improved flow & clearances all while giving you extra strength for power adders down the road. We have done several h/c setups with the 235/239 & PRC 260s well past the 525rwhp mark depending on mods around the setup. That being said lots of guys have gone well past 500rwhp with the PRC ported stock exchange heads & had money left in their pocket!! http://www.texas-speed.com/p-4010-pr...der-heads.aspx http://www.texas-speed.com/p-1388-pr...d-porting.aspx |
11-04-2014, 11:57 AM | #6 | |
14' Camaro 1LE - Now self-tuned
FRH ported heads, Cam Motion LL solid roller, Jesel rockers, Morel lifters, Kooks headers, Corsa exhaust, ADM intake, Stock compression/bore/stroke 551whp 504wtq |
11-04-2014, 02:03 PM | #7 | |
My immediate goal is to break 500rwhp. But if it's possible, over 520 would be awesome! I'm at 461 right now.
Taco's 2014 SS
11-04-2014, 03:17 PM | #8 |
Depends on the cam & if its a L99 or LS3. Typically 66-68cc...
11-04-2014, 08:54 PM | #9 |
Went with Mast Medium 256 11 degree Black Labels here.
Make that Black Label LS7 Heads.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly Last edited by SSBUSDRVR; 05-27-2016 at 04:22 PM. |
11-05-2014, 03:24 AM | #10 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
From what I recall there was a pretty big price difference between the Mast and aftermarket PRC casting LS3 heads when I got my PRC heads. Are those Mast heads a little better? Maybe but I just couldn't justify the price difference. I was already paying double the price for a aftermarket casting vs using a ported stock casting so I personally couldn't justify the price difference. If I had a unlimited budget then it would have been Mast all the way. I would recommend that you get hollow intake valves for whatever aftermarket heads you end up with. L92 intake valves are probably the heaviest of all stock LSx heads and the solid valves that any of the aftermarket heads come standard in are heavier than those. For valve train stability and longevity get the hollow valves. You don't want to become another statistic with all the valve train failures. You might look at the Trick Flows as well if and only if they have sorted out the issues with them. As far as the PRC's I would get the 255cc instead of the 260cc but that's just me. The 260 will probably make more peak power but the 255 will have better power through the curve. Also, don't expect a huge increase in power with the aftermarket castings vs using a quality ported stock casting. The only reason I went aftermarket casting was because I had FI in mind for the future so I wanted a thicker deck and the ability for a 6 bolt head.
11-05-2014, 06:30 AM | #11 | |
Thank you for the valve train info, I'll have to look into that further.
Taco's 2014 SS
05-27-2016, 09:01 AM | #12 |
Drives: camaro Join Date: Dec 2013
So what did you go with what heads
05-27-2016, 02:30 PM | #13 |
I wouldn't touch the PRC heads. Shouldn't even be considered an option, even if they were free.
Nick
05-27-2016, 02:34 PM | #14 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Wow... that's strong. What happened that I missed? Seriously interested in knowing.
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
