02-08-2024, 08:30 AM | #1 |
Drives: 2015 Camaro SS Join Date: Dec 2018
Borla Exhaust install question
I'm installing a Borla S type axle back on my 2015 Camaro SS. Directions say to cut 2.32" from box seam. When you look at stock muffler there is really no defining box seam. Any one with information where they measured from would be greatly appreciated. Tried attachment picture don't know if it loaded
02-08-2024, 08:41 AM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I don't have a measurement for you, but I can tell you when I did mine, I cut at the weld on the muffler to give me as much pipe as possible and then put the new muffler in position so I could see where to cut again. Of course, I did not read the instructions.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
02-08-2024, 08:53 AM | #3 | |
02-08-2024, 01:32 PM | #4 | |
02-08-2024, 01:53 PM | #5 |
Found the measurement place on youtube
02-10-2024, 01:54 PM | #6 |
Update- I ended up measuring from the horizonal seam on the muffler 2 1/4" hopefully to give me some extra adjustment. If I was to do it again I would use 1 1/2" instead to give room for adjustment. I made the 2. 1/4" work, more so because I had a couple 2 bolt stainless lap band clamps so I could cheat some. Borla tec support wasn't much help in my opinion. Never replied to email and tec on phone couldn't tell me where to measure from only say just hold it up under the old muffler and eye ball. Right and your instructions say 2.32
