03-11-2020, 12:53 PM | #1 |
Drives: 2017 Camaro 1SS Join Date: Apr 2019
Audio shutting off when Voltmeter reads above 15V
I have a 2017 1SS with a non-bose system. Intermittently the amp output will go away. Sometimes you can hear a crackle, and sometimes it may go in and out. I noticed it happens more frequently the colder the outside temperature is. Also, the voltmeter reads above 15V and I check the voltage at the battery and it is 15.25 or greater when this happens.
I am thinking either the amp is bad or the voltage regulator? Thanks for the incite! Jaymee |
03-11-2020, 01:42 PM | #2 |
Drives: 2019 Camaro SS M6 Join Date: Jan 2020
Agree with voltage regulator is bad. Replace alternator or replace both a battery and alternator. Sooner than later. Good call!
03-11-2020, 01:58 PM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
Either way it should be covered if you car is still within the warranty period.
03-12-2020, 10:07 AM | #4 |
Thanks guys! It's just out of warranty. Just my luck. It's interesting it only does it every now and then. I will look into having the alternator checked. The battery is 3+ years old now so I will replace it in the next few months either way.
Jaymee |
03-13-2020, 11:13 PM | #5 | |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
Open up the amplifier and make sure there is enough heat sink grease on all the power amplifies, or it’s not dried up. This may be a best case chance at fixing it. GM requires that we mute the audio power amplifiers when the battery is 16.0 or greater. There is no problem to operate these parts at 15.0V. So, don’t waste your money on regulators, or batteries.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
03-20-2020, 10:04 AM | #6 | |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
https://www.harborfreight.com/infrar...ter-93984.html |
03-24-2020, 03:14 PM | #7 | |
Go to your local PC part place, or ebay, spend $2 and give it a whirl. You may do more damage operating the amplifier opened up. I do, however, suspect the power amplifier IC has failed.
04-20-2020, 07:53 AM | #8 |
I took the amp apart. The heat sink compound was drying and flaky. I cleaned all that up and added some fresh new compound. The ambient temps have been warm enough that i haven't had the problem yet. Keeping an eye on the volt meter in the dash, the voltage has been less than 15 since i looked at the amp.
I did purchase a new alternator. I was going to install it just to see, except I haven't figured out how to release the serpentine belt tensioner yet. The alternator seems like an easy change, once that belt is off and out of the way. Thanks for all the insight! Jaymee |
