10-01-2019, 09:18 PM | #1 |
Drives: 09 silverado 1500, 15 camaro ss Join Date: Sep 2019
do i have ported and milled heads ?
picked up a 2015 ss ls3 theres a chances the heads have been ported and milled by texas speed in its past life.
would there be any dead give aways i could look for or a way i could tell without taking the heads off ? thanks |
10-01-2019, 09:31 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Pull a header or intake manifold and check out the ports be the only way
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
10-01-2019, 09:34 PM | #3 |
With a scope you could go in though the spark plug hole and maybe look up and see , but that one is not going tell very much of what's been done , going to be very hard to get the scope looped up to see the combination camber
10-01-2019, 09:35 PM | #4 |
I was going to pull the intake, what should I be looking for ? To see if the cast markings are all grinded down?
10-01-2019, 09:43 PM | #5 |
I was told they were ported and milled to 68cc by texas speed. but that didn't really make sence to me, I thought 68cc was stock
10-01-2019, 10:17 PM | #6 |
Should be easy to spot once intake manifold is off , smooth and hogged out intake ports will look very diffrent than untouched head , no casting ruffness and rounded off everything
10-02-2019, 06:01 AM | #7 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Whenever I mill a head and most machine shops will stamp the head with the amount removed, for example 030. Porting is obvious with intake or exhaust removed .
10-02-2019, 09:51 AM | #8 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Maybe Texas Speed logged the VIN? Call em.
10-02-2019, 10:57 AM | #9 |
The only reason I'm wondering is because I'm about to throw in a night fury cam with 7.4 rods and don't want any issues because of the milling.
I'll try and call them. Thanks |
10-02-2019, 03:44 PM | #10 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Stock and then ported
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-02-2019, 10:30 PM | #11 |
Ponies are for girls
Or just contact Texas Speed and give them the VIN and see if they've worked on it. Just a thought.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
10-06-2019, 08:03 AM | #12 | |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
If uncertain I recommend using a pushrod measuring tool to ensure you get the correct length. I have ported and milled heads from GPI. Chamber porting takes material away and milling gets back or close to stock.
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo GPI VVT SS1 cam and CNC ported heads milled .30 BTR .660 springs, Straub solid bushing trunions GPI rod-mod intake with I-M heat sheild Circle D 258mm Pro single disc 3700 rpm stall converter 169F thermostat & manual fan switch Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft |
