02-26-2014, 05:44 PM | #1 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Recommendations on auto stethoscope?
Trying to hunt down a noise that is coming from somewhere near the passenger chair (two dealers haven't found it). Any recommendations on a good car stethoscope / noise detector?
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
03-01-2014, 07:13 PM | #2 |
Drives: 2013 IOM 2SS 1LE Join Date: Aug 2013
Is it a "buzzing" sound?
03-05-2014, 08:12 PM | #3 | |
Drives: 2011 2SS/RS IOM/PEARL STRIPES-6M Join Date: Mar 2011
I purchased one of these over 25 years ago and it still works perfect. Easily pinpoints noise. http://www.amazon.com/Steelman-STE65.../dp/B000WNJ90W
Whipple S/C, 3.750 pulley, JRE rough idle blower cam kit, Trunion upgrade, C5R timing chain, LS2 chain dampner, Melling 10296, Dynatech 1 7/8 LT headers, OR pipes, Dual valve RX catch can, ID 850 Injectors, LPE Dual fuel pump, CAI with Apex scoop, VMax ported T/B, ADM Tune 675 RWHP 560 TQ
03-13-2014, 12:18 AM | #4 |
Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
Yes just get a snap on one
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
03-23-2014, 05:37 PM | #5 |
Banned
Drives: 2010 Camaro Join Date: Mar 2014
a long screwdriver to your ear . It really works!
03-23-2014, 06:07 PM | #6 |
Too much is never enough!
broomstick also works good...cut one about two feet give or take
you can also buy a automotive stethoscope from snap-on or mac tools
08-08-2015, 10:48 AM | #7 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
Had a weird noise last week. Went out to Sears and bought this stethoscope and pin pointed the noise coming from the water pump. Took my car to the dealer and the mechanic who works on my car came out with the same stethoscope. Sure enough the water pump. They replaced it under warranty. All good now and I have this cool tool that only cost 18 bucks. Should of had one of these a long time ago.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
